peterwmh Offline
#1 Posted : Wednesday, 24 May 2006 6:25:10 AM(UTC)
peterwmh
Hi all,
Needed new gas tank fitted to my vehicle for a RWC as the old one was too rusted. It was a very old tank, the existing dash gauge was dead too so the installer fitted a new tank and a new LED gas gauge on the dash. Problem is the gauge reads full all of the time. I have questioned it and they said the wiring is a bit dicky' in the car so you'll need to see an auto sparky to get it rectified. I'm thinking it can't be that hard surely. In summary it has an earth wire and a feed wire to the sender at the tank and 3 wiring input ports at the gas gauge on the dash. Can anyone assist me in the correct sequence of wiring this so that it'll actually read the fuel level that's in the tank!
Many thanks
Peter
Never late with a 308!!
#2 Posted : Wednesday, 24 May 2006 8:16:14 AM(UTC)
Hi
this is an easy one,the sender in the tank has 2 wires,one goes to earth and the other goes to the gauge,the gauge has 3 wires
one from sender,one earth and one 12 volts,
the sender and gauge must be matched 0-90 ohms,
to check tank wiring pull sender to gauge wire off sender,dash gauge should show full,hold sender wire to earth and gauge should drop to empty,if it dosnt drop gauge is faulty or wire is touching body.
hope this helps!!
if it aint broke we can improve it.
Cheers Steve
#3 Posted : Wednesday, 24 May 2006 8:16:14 AM(UTC)
Hi
peterwmh Offline
#4 Posted : Wednesday, 24 May 2006 7:35:56 PM(UTC)
peterwmh
Thanks Steve, much appreciated.
Peter
peterwmh Offline
#5 Posted : Wednesday, 24 May 2006 7:35:56 PM(UTC)
peterwmh
Peter
peterwmh Offline
#6 Posted : Monday, 29 May 2006 12:12:28 AM(UTC)
peterwmh
Still working on the problem, must have a short or break somewhere!!
Peter
Edited by user Monday, 29 May 2006 3:03:31 AM(UTC)  | Reason: Not specified
peterwmh Offline
#7 Posted : Monday, 29 May 2006 12:12:28 AM(UTC)
peterwmh
Peter
#8 Posted : Sunday, 25 May 2008 10:18:47 PM(UTC)
If it is reading full all the time, the wiring is earthing out between the tank and the gauge.
#9 Posted : Sunday, 25 May 2008 10:18:47 PM(UTC)
#10 Posted : Monday, 26 May 2008 1:23:51 AM(UTC)
I had an adapter arrangement in the Overlander that switched the feed to the stock Holden fuel guage dependant upon which position the LPG-OFF-PETROL switch was in. Worked well.
#11 Posted : Monday, 26 May 2008 1:23:51 AM(UTC)
If we all had the
christoss Offline
#12 Posted : Wednesday, 28 May 2008 10:23:13 AM(UTC)
christoss
A dead short to sender wire will cause low resistance to gauge thus reading empty 0ohm = no resistance, dead short
90 ohms = full, no continuity from gauge to sender , broken wire , high resistance
christoss Offline
#13 Posted : Wednesday, 28 May 2008 10:23:13 AM(UTC)
christoss
Bleggy Offline
#14 Posted : Thursday, 1 October 2009 1:52:39 AM(UTC)
Bleggy
our dash LPG selector switch fell apart and had to be replaced now We have the same question as Peter can some one halp us with the answer please, our guage constantly reads full but seems to run on Petrol all the time both on Petrol and on LPG
vintageholden Offline
#15 Posted : Thursday, 1 October 2009 3:12:45 AM(UTC)
vintageholden
sticky afl valve
give it a slight tap with hammer..............slight.....
main wire from gauge to tank might be cut
twin core under the car.....check the earth on the same wire ...black on fixed to chassis
ring AAA Autogas 94705090 welshpool W.A
ask for mark....
Edited by user Thursday, 1 October 2009 3:14:04 AM(UTC)  | Reason: Not specified
This page was generated in 0.206 seconds.
