vulcan2509 Offline
#1 Posted : Friday, 26 May 2006 6:21:19 PM(UTC)
vulcan2509
G'Day
I am in the process of builing up my old HD and I have the age old problem of the winscreen fogging up, so my question is, is there an Air Conditioning System from a later model or even an after market unit that may fit into the old girl.
Eddie
"With A Name Like Brock What Else Would I Drive"
#2 Posted : Friday, 26 May 2006 9:10:12 PM(UTC)
Hi Eddie, mate this maybe more than what your willing to spend but in my EH I run a Vintage Air heater/AC unit.
I tried heaps of small ricer units but they were all to big. The unit is just over $900 and then you still need your compressor, condenser et
#3 Posted : Monday, 29 May 2006 3:29:07 AM(UTC)
Thanks for the info, damn that looks tight with that V6 in there.
Eddie
vulcan2509 Offline
#4 Posted : Monday, 29 May 2006 4:05:41 AM(UTC)
vulcan2509
Sorry not loged on, thanks retro
Eddie
#5 Posted : Monday, 29 May 2006 9:36:43 AM(UTC)
I have an a/c unit out of a 85 or Daihatsu it is pretty compact and has the heater and blower and air all in the one unit, its pretty compact. I am planning to put it in a morris minor so one should go in your car.
I also have a heater/ blower unit out o
#6 Posted : Monday, 29 May 2006 10:21:56 PM(UTC)
For a start you can cross Nissan, Hyundai and Hondas off the shopping list as they are all to wide and high.
The great lack of wreckers up my way with a wide range of cars was my undoing......... but it is worth having a look, some of the bigger yards I'
vulcan2509 Offline
#7 Posted : Tuesday, 30 May 2006 4:53:37 AM(UTC)
vulcan2509
Thanks for that info, I might take a walk around pick&payless gotta love self help wreckers.
Eddie
#8 Posted : Sunday, 25 June 2006 2:39:50 AM(UTC)
i just went for a drive the some jap wreckers in my area. every unit that i found seemed to be to big to go under the dash......
does anyone have any idea's on what model of car i should be looking at?
michael.
#9 Posted : Sunday, 25 June 2006 3:41:08 AM(UTC)
Daihatsu's are small....... Like John has said above, have come across a few since I got mine and they may go close. Just try and get a unit that does not use vacuum (only cables) then you should be able to cut and shut the cable lengths to suit.
life'
#10 Posted : Sunday, 25 June 2006 10:27:16 AM(UTC)
Have a look on EBAY, theres a guy that sells a combined AC/Heater unit on there, its a small unit designed to fit under dash, very similar to the vintage air one, sell them for around the 200 dollar mark from memory
#11 Posted : Sunday, 25 June 2006 10:33:37 AM(UTC)
I would have thought the vacuum operated controls would be better, to alter the length of the hose just cut it, and you can go around corners easier.
#12 Posted : Sunday, 25 June 2006 9:58:26 PM(UTC)
Just a personal preference thing with the vacuum .... also so you can use the standard control's on the dash and then only need to fit a a/c "on" switch.
Thank god all the control's on mine are electric....
life's to short not to be....
#13 Posted : Monday, 26 June 2006 5:36:50 AM(UTC)
cheers for that ... i will go check out some older wreckers..
This page was generated in 0.088 seconds.
