HarryO Offline
#1 Posted : Tuesday, 13 March 2007 7:27:09 AM(UTC)
HarryO
Hi all,
In the process of lifting out & re-fitting a 186 from an EH. Previously lifted (engine crane) via exhaust/inlet studs at 2 points with chain, with nuts over the chain & (forget the tech name...) bolts into 2 of the covers on the other side. Worked fine, but makes me nervous with a swinging engine held by 4 bolts. Is this the correct way (prefer not to run chains under the sump, & prob not lift out well in any event)? Thanks.
peter_flane Offline
#2 Posted : Tuesday, 13 March 2007 8:07:29 AM(UTC)
peter_flane
2 bolts would be enough, so don't be nervous about 4 bolts.
#3 Posted : Tuesday, 13 March 2007 8:13:31 AM(UTC)
A high tensile bolt in the coil mounting thread and a high tensile bolt in the earth lead thread as always worked for me.
VL05 Offline
#4 Posted : Tuesday, 13 March 2007 8:23:48 AM(UTC)
VL05
Yeah mate I've lift a 253 with 4 bolts with ease.
WANTED: HJ Sandman parts, PM me!
WANTED: GTS rims, seats and mirrors to suit HJ.
HarryO Offline
#5 Posted : Tuesday, 13 March 2007 8:26:59 AM(UTC)
HarryO
Thanks for the input guys. Sets my mind at ease. Cheers.
boom Offline
#6 Posted : Wednesday, 14 March 2007 7:16:16 AM(UTC)
boom
253 with 2 bolts is still strong so a 186 should be a like a feather with 4
Fcuk Psi
HarryO Offline
#7 Posted : Wednesday, 14 March 2007 7:27:00 AM(UTC)
HarryO
Thanks mate. I see the engine swinging & automatically calculate who is at risk if one chain goes.
Then again, I am one of those people that when the front end is lifted & placed on stands, there are 2 'backup' stands also under the car, and the hydra
Edited by user Wednesday, 14 March 2007 7:28:04 AM(UTC)  | Reason: Not specified
#8 Posted : Wednesday, 14 March 2007 7:32:29 AM(UTC)
an ounce of prevention is better than a ton of cure...good to see i'm not the only safety freak ;)
i'd rather hated for who i am than loved for who i am not.
#9 Posted : Wednesday, 14 March 2007 7:40:37 AM(UTC)
You are better off to be safe than sorry. I have seen jacks go down on there own and a mate of mine got three fractured ribs when a jack let go on him. He was lucky it could have been worse.
