#1 Posted : Friday, 26 May 2006 7:56:55 PM(UTC)
EMAIL ENQUIRY FROM PETER:
hi
i want to change my GTS dash but cant see how to remove my HG ignition switch and headlight switch can you tell me how to
regards
peter
cedar vale
#2 Posted : Friday, 26 May 2006 8:59:56 PM(UTC)
For headlight switch removal instructions go to this topic:
http://www.fastlane.com....archTerms=switch,remove
I know it's a HZ but the switch is the same thing.
I tried to search for ignition lock removal but cou
#3 Posted : Monday, 29 May 2006 4:23:28 AM(UTC)
The information suggested is correct, however, when "reaching around the back of the light switch mechanism to push the release button", I think you will find it is actually on the top of the switch mechanism. It is a little tricky to find if you have not
#4 Posted : Monday, 29 May 2006 9:32:00 AM(UTC)
Best to disconnect the battery first as you are going to have live wires floating around and also you have to turn the lights on before pressing the little spring loaded button on the switch body behind the dash attempting to pull the switch rod/button ou
