#1 Posted : Tuesday, 6 June 2006 9:55:31 PM(UTC)
Hi
I have dropped a EFI V8 into my WB
I dont appear to have enough room for my air con as it is touching the steering box.
Has anyone got any suggestions on bracketing or placement to avoid deleting it all together
Any info would be great
WBGirl
#2 Posted : Wednesday, 7 June 2006 12:55:28 AM(UTC)
If you are running both the power steering pump and A/C you may find it easier to just get the pulley kit from V6conversion, think they are around the $300 mark..... I've only done V6's so cant say for sure if there is another way.
Cheer's
life's to s
#3 Posted : Wednesday, 7 June 2006 5:56:58 AM(UTC)
are you using the VN style power steering?
if so it should leave enough clearance.
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
#4 Posted : Wednesday, 7 June 2006 6:56:08 AM(UTC)
No I'm using PAS that came originally in the WB's
Thanks for your input it is appreciated
GMH1975 Offline
#5 Posted : Wednesday, 7 June 2006 6:04:44 PM(UTC)
GMH1975
I have the same problem with my HX.
I want to see if it is possible to modify the VP commodore aircon braket so the pump will clear the steering box.
Im thinking to either shorten the bracket to raise the pump or modify it to make the pump sit closer to
Not the BLOODY Kingswood
#6 Posted : Wednesday, 7 June 2006 8:04:32 PM(UTC)
Thanks for your input.
I am going to sit the engine in and go from there, i think modifying the brackets is probably the way to go.I will post another reply when i have a solution.
WBgirl
GMH1975 Offline
#7 Posted : Thursday, 8 June 2006 4:29:44 PM(UTC)
GMH1975
Another option might be to use a smaller aircon pump.
My wifes daewoo matiz has got a very small pump that might be okay to cool a ute but mostly likly not a sedan.
#8 Posted : Saturday, 10 June 2006 9:16:52 AM(UTC)
I have a few ac pumps and the one off the VS is a very small one, must be efficient though as it is stock.
#9 Posted : Friday, 16 June 2006 3:30:08 AM(UTC)
Thanks for your reply...
Looks like i may use an RRS (Revelation Racing Supplies)style pump as they are not much bigger than a coil.
WBGirl
