#1 Posted : Wednesday, 7 June 2006 7:52:58 PM(UTC)
Hi there, can anyone tell me if I can use a 149 standard camshaft in a standard 179?
#2 Posted : Thursday, 8 June 2006 9:04:42 AM(UTC)
john , yeh you can if you want , but why you would dio this?, if you have got this far get a replacement camshaft for your engine configuration , you can get a suitable grind to suit your engine specs and all will make sense, contact a local engine shop f
#3 Posted : Friday, 9 June 2006 7:51:25 PM(UTC)
Thanks for that Pete. I had new rings & bearing put in, but I didn't know it had a different cam from standard (motor was a non goer when I got it)
I've got a few 149's sitting around so was hoping one of those cams would fix work out ok......
