#1 Posted : Tuesday, 20 March 2007 5:18:14 AM(UTC)
rebuilt my 250 crossflow engine a few months ago and now it is making a high pitched whistling noise, it is making it between the gear box and the engine wheni put a cloth over it it sorta stops it but i can still her it when im under the car.
can anyone help plz any idea would be great thankyou
6pak Offline
#2 Posted : Tuesday, 20 March 2007 5:26:09 AM(UTC)
6pak
Hi Dwayne
You've probably already checked this but have you eliminated the possibility of a manifold leak?
#3 Posted : Tuesday, 20 March 2007 6:32:43 AM(UTC)
Originally posted by 6pak
Hi Dwayne
Dmax Offline
#4 Posted : Tuesday, 20 March 2007 8:32:33 AM(UTC)
Dmax
It will probably be a vacuum leak from the back of the carby or intake manifold. Possibly for the vaccum assisted controls (If xd onwards)or even to the brake booster.
Tunnel Rammed 351, It does not get any better
[img]http://i79.photobucket.com/albu
648hp Tunnel Rammed 351, It does not get any better
6pak Offline
#5 Posted : Tuesday, 20 March 2007 9:41:30 AM(UTC)
6pak
Hi Dwayne, Just out of curiosity is it a manual or an auto?
#6 Posted : Wednesday, 21 March 2007 7:51:47 AM(UTC)
it is a auto, an no i checked if it was coming from the carby but it is not when i was underneath the car at the rear of the sump thats is were it is coming from so im wondering if the rear seal need to be tighted more or something is stuffed or could it
Dmax Offline
#7 Posted : Wednesday, 21 March 2007 8:04:55 AM(UTC)
Dmax
There will be a vacumm hose to a valve setup on the auto, driver side on top at the front. This may have come loose. This helps it shift down. Without it, you'll find you need to get to about 80k's before it will shift into top. I cannot think of anyt
#8 Posted : Wednesday, 21 March 2007 8:29:07 AM(UTC)
fluid level is good checked that, ill check out the hose an get back to you on it thanks heaps.
#9 Posted : Wednesday, 21 March 2007 8:36:29 AM(UTC)
To help trace exactly where the noise is coming from, grab a length of ordinary garden hose (about 2' or 600 mm should be enough), stick one end in your ear and move the other end around until you find the source of the noise.
This also works really we
Edited by user Wednesday, 21 March 2007 8:37:15 AM(UTC)  | Reason: Not specified
Dmax Offline
#10 Posted : Wednesday, 21 March 2007 8:41:54 AM(UTC)
Dmax
Ouch!!!!
#11 Posted : Thursday, 22 March 2007 5:38:06 AM(UTC)
found out what it was.
i have a fuel injected tapped cover on the engine and i had the vacum holes sealed up and was sucking from the rear main seal at the back of the engine so i have fixed the problem thax fopr everyones help and ideas
#12 Posted : Thursday, 22 March 2007 7:55:33 AM(UTC)
Hi Dwayne,
Thanks for letting us know. :-)
Cheers...Dave
Dmax Offline
#13 Posted : Thursday, 22 March 2007 7:01:47 PM(UTC)
Dmax
Good stuff
This page was generated in 0.106 seconds.
