#1 Posted : Wednesday, 21 March 2007 2:47:42 AM(UTC)
My cousin bought a crappy electric supercharger the other day, and I must say it looks like a piece of crap. There is no way these things can work, right?
Dmax Offline
#2 Posted : Wednesday, 21 March 2007 8:09:29 AM(UTC)
Dmax
Depends on the power. If you have a motor that moves 300 cfm, and you get a fan that moves 500cfm, then you will at the least have positive pressure in your intake which is always better than a vacuum. Just got to have the right setup. You may only get
648hp Tunnel Rammed 351, It does not get any better
#3 Posted : Friday, 30 March 2007 2:05:43 AM(UTC)
I don't know, but I have found the idiots that sell these things www.electricchargers.com
#4 Posted : Wednesday, 4 April 2007 12:24:14 AM(UTC)
No they don't work.
It is just a fan, if the engine is idling it might be moving just enough air to increase the pressure in the intake by a tiny amount (if the pressure increased substantially then it would push its way back past the spinning fan blad
Dmax Offline
#5 Posted : Wednesday, 4 April 2007 2:14:16 AM(UTC)
Dmax
If you use a 500cfm fan on a 350 holley, the fan will be able to keep up with motor, no dramas. what will restrict the fan is the positive pressure which can only be created by the fan itself as the motor will try to create a negative pressure on the int
This page was generated in 0.121 seconds.
