#1 Posted : Thursday, 29 June 2006 12:31:13 AM(UTC)
i'm in the proces of working my 202 and i'm upto selecting the intake. Originaly i was gonna use a vk injection, but i just read elsewhere on this site that a 390 vac secondary or 465 holley work well on holden 6's.
So my question is which would be best to use 390, 465 or injectionfrom vk?
The motor is a red 202 stock bottom end, acl flat top pistons, come racing max efficiency cam. I plan to have mild porting done on the heads and better valve springs. i also have plans for an electronic dizzy and ignition.
The motor will be running straight gas.
Football, Meat pies, Kangaroo's and Holden cars
#2 Posted : Thursday, 29 June 2006 1:47:58 AM(UTC)
Hi 10000 fists.
You mention you have Holden Red bottom end, but don't mention the head. If it's also a Red you the VK injection inlet manifold won't fit, you really need to go to a Blue/Black 12 port head. Otherwise just fit the small Holley & MANIFOL
#3 Posted : Thursday, 29 June 2006 3:46:20 AM(UTC)
If you wish to run straight gas bypass it all and fit a gas carb.
I'm about to embark on a VP EFI V8 conversion, and will probably buy the Kalmaker programming software and associated stuff, so in the future once I understand the system I may be able to
#4 Posted : Thursday, 29 June 2006 7:38:17 AM(UTC)
If you want to tune it, try modifying you manifold to take injectors and run megasquirt. i'm using it on my bike at the moment.
#5 Posted : Saturday, 1 July 2006 10:52:59 PM(UTC)
Hi all thanks for your replies.
Dr Terry i have both a red and a blue head, which on i use will depend on which intake i use.
Byron at the moment i have an impco converter(on the 202 in my car) that's busted and needs to be replaced.... if i go stra
Edited by user Monday, 3 July 2006 8:05:00 AM(UTC)  | Reason: Not specified
