i'm in the proces of working my 202 and i'm upto selecting the intake. Originaly i was gonna use a vk injection, but i just read elsewhere on this site that a 390 vac secondary or 465 holley work well on holden 6's.
So my question is which would be best to use 390, 465 or injectionfrom vk?
The motor is a red 202 stock bottom end, acl flat top pistons, come racing max efficiency cam. I plan to have mild porting done on the heads and better valve springs. i also have plans for an electronic dizzy and ignition.
The motor will be running straight gas.
Football, Meat pies, Kangaroo's and Holden cars
Hi 10000 fists.
You mention you have Holden Red bottom end, but don't mention the head. If it's also a Red you the VK injection inlet manifold won't fit, you really need to go to a Blue/Black 12 port head. Otherwise just fit the small Holley & MANIFOL |
If you wish to run straight gas bypass it all and fit a gas carb. I'm about to embark on a VP EFI V8 conversion, and will probably buy the Kalmaker programming software and associated stuff, so in the future once I understand the system I may be able to |
If you want to tune it, try modifying you manifold to take injectors and run megasquirt. i'm using it on my bike at the moment.
Hi all thanks for your replies. Dr Terry i have both a red and a blue head, which on i use will depend on which intake i use. Byron at the moment i have an impco converter(on the 202 in my car) that's busted and needs to be replaced.... if i go stra Edited by user Monday, 3 July 2006 8:05:00 AM(UTC)
| Reason: Not specified
