hainzy Offline
#1 Posted : Thursday, 6 July 2006 6:12:59 PM(UTC)
hainzy
Hi all.
Did the HZ sandman have a white or yellow needle GTS dash?
Rhys Offline
#2 Posted : Thursday, 6 July 2006 6:55:47 PM(UTC)
Rhys
Yellow needle. All HZs and WBs out of the factory had yellow needle dashes (except Statesmans)
Also the HZ Sandman had a HZ GTS steering wheel. The wheel was identical to HX but the horn cap had a round holden badge in the centre and no bolts around th
#3 Posted : Thursday, 6 July 2006 7:46:50 PM(UTC)
The wheel you are talking about is the same as late HZ GTS's, HZ SL/E, late toranas (incl UC) etc. The HZ SL/E Statesman also had the yellow needle dash.
hainzy Offline
#4 Posted : Thursday, 6 July 2006 8:23:49 PM(UTC)
hainzy
Great thanx guys. The sandy I have (Byron you know the van),has had the original GTS dash sold out of it, so i guess Im looking for one with the yellow needles. If anyone has one for sale.....?
Cheers.
#5 Posted : Friday, 7 July 2006 12:20:54 AM(UTC)
Hi Byron.
Why do you say 'Late' HZ GTS for the steering wheel, AFAIK all HZ GTS had this wheel.
Dr Terry.
#6 Posted : Friday, 7 July 2006 4:01:00 AM(UTC)
Terry, you are no doubt correct. I've only ever seen late(r) original HZ GTS's, so my experience so far tells me that late HZ GTS's have them. I've not seen an initial release HZ GTS as an original car so I'm guessing to say they all had them. My real poi
#7 Posted : Friday, 7 July 2006 4:56:55 PM(UTC)
The wheel was also optional on Premier and I think others. But 100% on Premier.
They were also 100% on early GTS.
Warren
#8 Posted : Friday, 7 July 2006 6:48:26 PM(UTC)
Interestingly my HZ BO6 (ambulance pack) tonner came standard with a black wheel, with the earlier cap the same as an LX SS (ie blank).
I think I have one of the later caps NOS somewhere at home. I think it's a tan one.
#9 Posted : Friday, 7 July 2006 7:16:48 PM(UTC)
Hi Guys.
The BO6 Ambulance pack had the base model 2 spoke steering wheel, many were replaced with a GTS wheel from the spare parts dept. of the selling dealers, because the stock wheel looked crook in basic black. The older style GTS bolt-on cap would
Jvanner Offline
#10 Posted : Friday, 7 July 2006 10:36:29 PM(UTC)
Jvanner
About the dash. on the fuel gauge. is it a fuel pump or a jerry can. What year did they change? i mean did the white needle dash have a jerry can and a yellow needle have a fuel pump..... Jamie
#11 Posted : Friday, 7 July 2006 11:15:07 PM(UTC)
Hi Jaime.
Yes, the symbols changed at the same time as the needle colour (& shape). The jerry can belongs to HJ & HX, while the fuel pump is correct for HZ & WB.
The HZ/WB symbols are to the newer 'ISO' standard & just about every symbol on the dash
Guest (6)
