#1 Posted : Friday, 7 July 2006 5:37:04 AM(UTC)
hi,
whats the best way to remove the front glass out of a hq-wb 1 tonner cab? (without breaking it would be helpful)
cheers guys
#2 Posted : Friday, 7 July 2006 9:55:49 AM(UTC)
Use a sharp knife use water to make it cut easier. Cut the rubber and gunk away. If it is atoughened glass it will take a bit of handling .
If it is laminated (it will be marked laminated or toughened) it is very fragile and will not tkae any harsh treat
#3 Posted : Saturday, 8 July 2006 7:20:49 AM(UTC)
cheers mate,will give it a go and see what happens.
#4 Posted : Saturday, 8 July 2006 10:51:10 AM(UTC)
Correction...that should read you can get toughened ones pretty cheap. Laminated are harder to find because they always break them.
Taz2 Offline
#5 Posted : Saturday, 8 July 2006 9:28:14 PM(UTC)
Taz2
The "other" way is to sit in the middle of the front seat and with your feet spread across the width of the screen near the sides, then push outwards evenly & slowly on the screen. Most screens will pop out, but you should only do this in warm weather whe
In thrust we trust
#6 Posted : Monday, 10 July 2006 10:58:29 PM(UTC)
I was scraping a bit of rust away at the bottom of the screen with a screw driver. No great deal of force and BOOM! The screw driver caught the corner of the wind screen and it blew out. Be careful. I still carry the scars.....well my undies do.
#7 Posted : Tuesday, 11 July 2006 1:33:34 AM(UTC)
peter_flane Offline
#8 Posted : Tuesday, 11 July 2006 4:21:07 AM(UTC)
peter_flane
Trade price to supply and fit almost any screen (rarer import and some 4WD and commercial not included) should be about $165. You can get cheap laminated screens that quite often start bubbling apart at the edges quite quickly for that price, or spend an
#9 Posted : Monday, 17 July 2006 9:29:32 AM(UTC)
Well a couple of weeks ago I got the window people out to fit new windscreen to the Subaru (insurance paid). The screen has a removable chrome front rubber back moulding. The moron whipped out his cutter and cut the moulding off. He reckoned they were har
Guest (10)
This page was generated in 0.092 seconds.
