#1 Posted : Sunday, 9 July 2006 6:02:58 AM(UTC)
hi all im new to the site so i hope im doing this right.
ive had problems with the enigine running really rough but only when it gets to 80kmh.any where under 80kmh it runs like a dream but at 80kms it feels like its running on 4 cyls and the trany starts banging in and out with the kick down, any ideas before i burn it lol. Brett...
FastEHHolden Offline
#2 Posted : Sunday, 9 July 2006 6:25:52 AM(UTC)
FastEHHolden
Could be coil breaking down or other ignition fault...check plugs leads and cap..after that its coil and module..so best check the small things first.
Could also be a blocked fuel filter...starving for fuel at higher revs.
Also check for air leaks i
#3 Posted : Sunday, 9 July 2006 6:27:14 AM(UTC)
FastEHHolden
If you do burn it...can you do it out front of my place?
#4 Posted : Sunday, 9 July 2006 6:36:03 AM(UTC)
i know its not a vacume leak cos its recently had a new manifold gasket fitted and all the hoses replaced and plugs and leads about 6 mnths ago.
how do i tell if the coil is stuffed and where is the module.
#5 Posted : Sunday, 9 July 2006 6:52:17 AM(UTC)
FastEHHolden
Borrow a manual for a start.
Ignition Coil
To Test Resistance:
@ 20°C
Primary
0.52 to 0.7 Ohms
Ignition Timing (Base)
@ Idle, Vacuum Hoses disconnected
12° BTDC
Distributor Pickup
Should have continuity across terminals.
I used to have
#6 Posted : Sunday, 9 July 2006 8:54:27 AM(UTC)
thx for your input fasteh.
i will check the coil out tomorow and the manifold bolts are fine.
i should also mention that if i keep driving the car while its playing up it will completly die out till out wont drive no more(not stall)and the exhaust will
peter_flane Offline
#7 Posted : Sunday, 9 July 2006 9:11:33 AM(UTC)
peter_flane
Dry solder in the computer?
#8 Posted : Sunday, 9 July 2006 9:17:30 AM(UTC)
what dry solder in computer??
#9 Posted : Monday, 10 July 2006 2:20:32 AM(UTC)
well its not the coil or the other ignition items ...
Rockett Offline
#10 Posted : Monday, 10 July 2006 4:26:28 AM(UTC)
Rockett
Years ago My sisters VC ratteled a baffle loose in the exhaust and clogged the exhaust totally with same general faults to your car. I believe this is not an uncommon fault. Just another possibility worth checking out.
Good Luck
Regards Rockett.
#11 Posted : Monday, 10 July 2006 5:22:05 AM(UTC)
FastEHHolden
Thats a good one to check...drop the pipe off in front of the muffler.
#12 Posted : Monday, 10 July 2006 7:53:08 AM(UTC)
Thx guys ill check that one out..
#13 Posted : Monday, 10 July 2006 7:55:23 AM(UTC)
if i cant rectify this problem i might consider dropping in a v6 in to it..
the car is too nice to burn...
peter_flane Offline
#14 Posted : Tuesday, 11 July 2006 4:04:48 AM(UTC)
peter_flane
#15 Posted : Tuesday, 11 July 2006 5:54:28 AM(UTC)
thx peter ill try that out.this problem is really doin my head in and the mechanics dont want to help...
Guest (16)
This page was generated in 0.120 seconds.
