#1 Posted : Monday, 10 July 2006 5:41:24 AM(UTC)
Just checked the stamp on a 186 stored in the shed. Just doing some plans for a rebuild, checked the pad on the right hand engine mounting, which is stamped with 186P. Checked the manual, gave options of 186A (High Performance) & 186K (X2). Where does 186P leave me?
Rowdy
#2 Posted : Monday, 10 July 2006 6:23:05 AM(UTC)
P is HK/T/G
#3 Posted : Monday, 10 July 2006 6:28:10 AM(UTC)
Thanks Paul,
came out of a HR, was told, it was the original....live and learn, live and learn!!
#4 Posted : Monday, 10 July 2006 6:38:07 AM(UTC)
No problem Rowdy, just passing on what I have learnt here, mainly from Byron, Dr Terry and Warren. Someone will correct me if I get it wrong.
Yep you gotta be armed with all the facts before you spend your $, keep hanging around here you will learn lot
#5 Posted : Monday, 10 July 2006 6:21:19 PM(UTC)
Hi Rowdy.
Just to clear up the 186 prefixes.
186A = 186 hi-comp (not high performance) HR
186K = 186 X2 & 186 S HR (not just X2)
186P = 186 hi-comp HK/HT/HG
186S = 186 S HK/HT/HG
186L = 186 lo-comp HK/HT/HG
Dr Terry.
#6 Posted : Tuesday, 11 July 2006 4:46:17 AM(UTC)
Doc & Paul,
Had a HR given to me, it's sat in the Shed for 18 months, so have finally decided to have a crack at a resto. Never thought the research and planning was so involved, but I want to do it right, so thought I'd hit the books and plan
barnsey Offline
#7 Posted : Monday, 18 December 2006 1:34:40 AM(UTC)
barnsey
found this site the other day whilst browsing the net, it lists all the holden six numbers ie: just a sample from this site. better to open the link as everything is in colums and easier to read.
barnsey
http://users.mrbean.net.au/~rover/choosing.htm
M
Edited by user Monday, 18 December 2006 1:36:20 AM(UTC)  | Reason: Not specified
#8 Posted : Monday, 18 December 2006 7:09:06 AM(UTC)
There are some ommissions and errors on that site IIRC, but most of it is correct.
