VL05 Offline
#1 Posted : Tuesday, 11 July 2006 7:59:11 AM(UTC)
VL05
G'day guys, while this might seem stupid just a couple of questions, given I'm looking for a simple torque wrench for minor car work (nothing too advanced).
1) What price should I be looking at spending? I've seen prices range from $30-$400.
2) What do the specifications in inches refer to?
3) Should I bother considering different brands or are they all the same?
Thanks in advance, Conor.
WANTED: GTS rims, seats and mirrors to suit HJ.
GMH1975 Offline
#2 Posted : Tuesday, 11 July 2006 5:23:02 PM(UTC)
GMH1975
I bought a kingcrome one from bunnings for $90.
Will be good for most bolts on a car .
The only thing it cant do is sump bolts on a 308 cos it cant be set so low.
They usually have measurements of Nm(newton meters) or lbs(pounds persquare ince i think)
Not the BLOODY Kingswood
#3 Posted : Tuesday, 11 July 2006 6:16:12 PM(UTC)
Hi Guys.
The common unit for a torque wrench are Nm (/Newton metres) for the newer cars & ft/lb (foot pounds) for the older cars. There is smaller version that was once common use on automatic transmissions that used in/lb (inch/pounds), you don't need
jabba Offline
#4 Posted : Thursday, 13 July 2006 5:32:20 AM(UTC)
jabba
There are two main types. There are the clcickers and the thumb knockers. The clickers you set the torque reading by twisting the end, and when you get to the right torque, it clicks at you. The thumb knockers are set by sliding a pointer up the torque
#5 Posted : Thursday, 13 July 2006 7:15:30 AM(UTC)
yeah spend about $100 and you should be right if ur only using it now and then. i used to sell them ranging from about $50 to about $5ooo, and for $50 youd be more accuarate guessing when its tight enough id sell a $400 - 500 one to a mechanic and the 5gr
#6 Posted : Thursday, 13 July 2006 7:42:50 AM(UTC)
Norbar is one of the better brands you can buy, if not the best.
Item number 11068 is a 1/2" drive 20-110 ft/lb (30-150Nm)
$255 and its good quality stuff
http://www.justtools.com.au//prod2822.htm
The "specifications in inches" just means that it
BrianH Offline
#7 Posted : Thursday, 13 July 2006 9:17:18 AM(UTC)
BrianH
Conor
The most common brand I have seen in automotive workshops and TAFE coleges over the last forty years is the Warren and Brown. I have seen new ones recently for about $400.
A couple of years ago I bought an old W&B with no visable signs of dam
#8 Posted : Thursday, 13 July 2006 9:35:29 AM(UTC)
Ah that old chestnut :-)
I made one of these in tradeschool 18 years ago, exactly the same.
http://i9.ebayimg.com/05/i/07/9b/da/85_1.JPG
Thats why theres heaps at tradeschool, we all left them there. I also made one in high school year 11.
Not havin
CherryBomb Offline
#9 Posted : Friday, 14 July 2006 6:42:39 AM(UTC)
CherryBomb
And for Gods Sake, What ever you do. Dont use it for any thing other then Tightning Bolts up!!
NEVER use them to undo Bolts. It can throw out the tention or bend (even if you cant see it!) the main bar, Giving inacurate readings.
Dan
Never stop
Never stop being inspired,
BrianH Offline
#10 Posted : Friday, 14 July 2006 6:54:28 AM(UTC)
BrianH
Rig
Why did you leave them there? Didn't they pass the accuracy test?
Yes that is the type but I don't think mine was made at a trade school unless the schools attach W&B name plates to them. They are simple and they work but they were not cheap
#11 Posted : Friday, 14 July 2006 5:51:17 PM(UTC)
Hi Guys.
jabba said
"The clickers are more compact and accurate"
I've found exactly the opposite. Yes, the clickers are more compact but a W & B type will kill them for accuracy & reliability any day. We get our torque wrenches checked/calibrate
#12 Posted : Saturday, 15 July 2006 10:16:30 PM(UTC)
I prefer the "deflection bar" type of toqure wrench as you can both see and hear when the limit is reached. Also when you tightning up stuff and it starts to feel doggy you can look at the bar and see how far you have left to go so you can stop or carry o
Sandman Offline
#13 Posted : Sunday, 16 July 2006 1:24:08 AM(UTC)
Sandman
They are like everything you buy. You get what you pay for.
I've been a mechanic for 30 yrs and always had W&B torque wrenchs. Never had a problem. Coupla rules, NEVER EVER undo bolts with them, as someone else said it can change the calibration on them.
