#1 Posted : Wednesday, 28 March 2007 10:25:12 AM(UTC)
Having problems with my VS Calais supercharged V6. Every now and then it will lose all power above 4,000 revs. Just has no power and wont rev any higher. Figured that the ECM is seeing a problem and pulling all the timing out. The problem is intermittent, but when it happens and I check the ECM for trouble codes, I'm getting code 46 and 47 which seem to be primarly related to the ignition control module. I pulled the module today and cleaned all the crap off it, also cleaned the coil packs and check the plug to the crank sensor. Will see how it goes in the next few days, and advise or tips on finding this fault?
#2 Posted : Thursday, 29 March 2007 9:17:07 AM(UTC)
Car seemed good today after cleaning and re-seating all the connectors etc. Only did the run to school though to pick up the young bloke and to the shops. Will see how it goes tomorrow on the run to work, the fault is very intermittent!
#3 Posted : Thursday, 29 March 2007 11:54:16 AM(UTC)
Not 100% sure which V6 it relates too, but some have a problem with the bit the coilpacks mount to cracking and causing ignition trouble. It may be worth checking that out.
Cheers...Dave
#4 Posted : Friday, 30 March 2007 8:50:12 AM(UTC)
Car played up again today, it's a 96 VS Calais supercharged. Yeah I'm thinking the ignition module from the codes and info in the manual, that's the flat part under the coil packs that the coils plug into. Think I'll try replacing it, any ideas where to g
#5 Posted : Friday, 30 March 2007 11:00:37 AM(UTC)
That's what it is called...I had a mental block on the name of it last night :-)
AFAIK, they are still available new. Get a price from a couple of Holden Dealers as their prices DO vary (sometimes by quite a lot) and also try REPCO or Coventrys (if you
Edited by user Friday, 30 March 2007 11:01:28 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, 2 April 2007 5:49:27 AM(UTC)
any vs to vy coil pack will do the job it will set u back around $120 also check your knock sensor connections thats why it wont rev any higher than 4grand to save itself from detonation
#7 Posted : Tuesday, 3 April 2007 10:48:38 PM(UTC)
I think that the ignition module underneath the coil packs is often referred to as the DFI.
It ****s me to tears when the media & state politicians re
This page was generated in 0.106 seconds.
