#1 Posted : Monday, 17 July 2006 6:38:58 AM(UTC)
On the Cheap how can i get my XF Carb going better.
I have been told a E2 Head will help is that true?
I am getting new Headers and Intake but what elses can i do on the cheap.
I plan to get a 2nd head to do the cam and valves soon but really want to get it going before i do that.
#2 Posted : Monday, 17 July 2006 7:02:03 AM(UTC)
turbo-charge it or put a V8 in it.
#3 Posted : Monday, 17 July 2006 7:31:24 AM(UTC)
I was thinking of turbo, but i only want to get the thing going first then i will look at spending the big bucks, as for V8 i will be starting a XD project next year and will be doing my 351 up then.
#4 Posted : Monday, 17 July 2006 7:35:36 AM(UTC)
I am thinking of doing the same, but i dont think the E2 will work on the non fuel injected block, but i maybe wrong.
#5 Posted : Monday, 17 July 2006 5:27:39 PM(UTC)
e2 head will go on an efi block,there the same.
#6 Posted : Monday, 17 July 2006 8:48:44 PM(UTC)
But will a E2 go onto a standed (unleaded nonfuel injected) block, and if it does will it get better performance.
#7 Posted : Tuesday, 18 July 2006 12:53:19 AM(UTC)
All right i have found out that the e2 will fit but i dont know if it will do much.
#8 Posted : Tuesday, 18 July 2006 8:28:59 PM(UTC)
The EFI XE had a really low compression ratio (8.8:1 from memory). The XF EFI probably had a low compression ratio also athhough it did have a better ECU than the XE.
Based on this information I would suggest that an XF EFI head will drop your compr
