killaxd Offline
#1 Posted : Sunday, 23 July 2006 7:34:42 AM(UTC)
killaxd
hi,i've just purchased a 351 windsor and want 2 put my clevo heads on it ....watz the good and bad points of this?? and watz involved in putting them on as i guess there not a bolt on swap, and wat manifold should i get 2 fit?? any info on this would be very much appreciated
XB351 Offline
#2 Posted : Monday, 24 July 2006 3:34:57 AM(UTC)
XB351
you need boss pistons or pistons with valve reliefs in the required areas if you cam lift is excessive. Don't want to be wacking valves into pistons now do we. They are practically bolt on but you will have to seal up a coolant hole in the head. Can't rem
killaxd Offline
#3 Posted : Wednesday, 26 July 2006 7:27:23 AM(UTC)
killaxd
ok thanx......anyone wit ideas on the manifold??
XB351 Offline
#4 Posted : Saturday, 29 July 2006 12:55:33 AM(UTC)
XB351
quite a few companies make manifolds. It's a matter of you asking them to make one to suit. Funel web, TFC and CHI all do manifolds for boss engines.
