#1 Posted : Tuesday, 25 July 2006 4:13:46 AM(UTC)
wishing to confirm a few basic things about holden motors.
are all the six cylinder motors basicly the same in the mountings both the engine mounts and the gearbox flange where the bell housing mates up.
Similarly what about the V8's. I gathere the 8's are different to the 6's, diferent bell housing, different mounts.
Are the V8's the same as the small chevies.
not much interested in the new fangled bent 6's but I would expect they would be different again
digressing slightly how much do the clutch arrangements vary.
I know that the V8 input shaft is longer.
All so I can understand what fits in what & what gear boxes mate up.
I'm a manual man so the various auto variations arent of much interest unless it makes the motor different.
thanks chaps
You can't win if you don't finish.
#2 Posted : Tuesday, 25 July 2006 5:29:41 AM(UTC)
Was thanked: 608 time(s) in 575 post(s)
Forgetting the pre 1963 'grey' motors, all Holden 6 cylinders from 1963 (EH) to 1985 (VK) have the same bellhousing pattern. The starfire 4cyl (1979-1983) is also the same. The clutches were basically the same from 1963 through to 1979 and starfire 4, exc
#3 Posted : Tuesday, 25 July 2006 8:48:23 AM(UTC)
thanks for your comprehensive reply.
seems things are much simpler with a six.
#4 Posted : Tuesday, 25 July 2006 8:51:08 AM(UTC)
Just to add to Byron's comprehensive post above...the Holden V8 mounts, etc are different to their Chev equivalents.
The only thing that the Holden V8's and the Chev V8's share is the bellhousing pattern on some of the Holden V8's as Byron pointed out
#5 Posted : Tuesday, 25 July 2006 6:15:58 PM(UTC)
Hi Guys.
To add to what Byron has said, all Holden sixes from the 48 series to VK have the gearbox bolt pattern & the clutches on Grey motors are the same as early Reds. The Grey crank has a different bolt pattern & unique engine mounts.
Dr Terry.
#6 Posted : Wednesday, 26 July 2006 8:26:38 AM(UTC)
Do you know I've not seen this all in one place before.
#7 Posted : Wednesday, 26 July 2006 1:27:54 PM(UTC)
I agree with you Clutch Car Go... Could make a book outta this stuff!
Thanks from me too byron - my UC is undergoing VT Series 1 304 transplant early next year, i now know that my engine mounts are good to stay!! Woo Hoo!!
Keith
[img]http://mem
#8 Posted : Wednesday, 26 July 2006 6:43:14 PM(UTC)
What gearbox are you going to use in the UC behind the 304?
#9 Posted : Friday, 28 July 2006 3:58:40 AM(UTC)
perhaps the moderators of the board would consider a view only forum where they could put choice and helpfull coppies of informative posts and links as requested or when they feel like it.
a woodworking bb I go on has this and it is quite popular, some a
This page was generated in 0.099 seconds.
