#1 Posted : Thursday, 27 July 2006 3:47:27 AM(UTC)
will all of the parts off a 253 go onto a 308 block, ie heads, cam, everything, can i put everything from a 253 block into and onto a 308 block. if not what will and wont. thanks
#2 Posted : Thursday, 27 July 2006 5:51:07 AM(UTC)
From Memory which Isnt that great I dont think you can use the heads Or The Cam But I think everything Else Is the Same ie fuel pump water pump Alternator and the Manifold Is Different also
crowe Offline
#3 Posted : Thursday, 27 July 2006 6:05:20 AM(UTC)
crowe
Not the crank, piston, and cam
#4 Posted : Thursday, 27 July 2006 6:54:55 AM(UTC)
Heads are identical as are all bolt-ons (with the possible exception of the gearbox if the 308 is a Turbo Pattern Block.
Crank, pistons and cam are different.
Cheers...Dave
#5 Posted : Thursday, 27 July 2006 7:00:36 AM(UTC)
Everything within a generation is interchangeable or the same except for the pistons & rings. By generation I mean within a particular evolution of the engine eg HT/G, or WB/VC/VH. Even the cranks interchange, however the 308 crank has heavier counterweig
