jimbobhtute Offline
#1 Posted : Saturday, 29 July 2006 2:06:04 AM(UTC)
jimbobhtute
G'day guys,
Can anybody tell me what this head is off?? - 7420081 - c3- 5 -6.
The wreckers at the local yard tell me that it is a standard 186 head, I'm a bit sceptical though, number doesn't look right... Is this number a low or high comp, and which needed for the standard 186 block??
cheers james
1970 Green HT UTE...
#2 Posted : Saturday, 29 July 2006 2:53:03 AM(UTC)
Hi jimbobute.
That number is the correct number for normal 179 & early 186 heads. It has the large combustion chamber so when it is fitted to a 'normal' stock bore 186 with std flat top pistons the comp ratio will be 9.2:1.
Dr Terry.
jimbobhtute Offline
#3 Posted : Saturday, 29 July 2006 5:31:41 AM(UTC)
jimbobhtute
Thankyou Dr Terry, Sounds good to me.
cheers james
