#1 Posted : Saturday, 29 July 2006 7:04:25 AM(UTC)
Rebuilding my Celica steel case after I bought it with a crushed front lower bearing. I've heard whispers that this can be replaced with a tougher needle bearing. Anyone done this? Would it just be a matter taking the ball bearing code in and having the bearing shop match it to a roller bearing instead?
BrianH Offline
#2 Posted : Saturday, 29 July 2006 8:46:53 AM(UTC)
BrianH
Spud
Try contacting this company in Sydney. They have been doing all kinds of things to Toyota boxes and fitting them into just about everything for decades.
http://www.dellowauto.com.au/
Brian
#3 Posted : Monday, 31 July 2006 5:51:35 PM(UTC)
Yes there is a way. I did the same thing and my local bearing shop helped me out. They actually listed a kit to do a Celica box for about $300.
Dellow won't help you with the part number for obvious reasons. They need to protect their own business.
#4 Posted : Tuesday, 1 August 2006 8:35:35 AM(UTC)
anthony.. this kit... was it just bearings or did it include other goodies?
You can't win if you don't finish.
#5 Posted : Tuesday, 1 August 2006 9:24:22 AM(UTC)
It was just bearings. But, one bearing was very hard to get and that bearing alone was about $100 from another supplier.
Also, I remember the sales rep telling me that the main Lay shaft bearing that is usually replaced with a double row needle roller
Edited by user Tuesday, 1 August 2006 9:28:02 AM(UTC)  | Reason: Not specified
#6 Posted : Tuesday, 1 August 2006 11:14:47 PM(UTC)
Numbers would be great if you've got them Anthony.
#7 Posted : Wednesday, 2 August 2006 1:58:36 AM(UTC)
NUP205ANC3 PZ 00504 It's a KOYA brand bearing.
Just check with your supplier first. It should be a needle roller bearing and not a Std deep groove ball type.
I have a dismantled celica box here that I checked and the sizes should be as follows OD 5
Edited by user Wednesday, 2 August 2006 3:21:54 AM(UTC)  | Reason: Not specified
#8 Posted : Wednesday, 2 August 2006 3:25:55 AM(UTC)
Thanks and. The bottom front bearing in mine just exploded, so definately want to replace with a roller type. I'll go in with the spec and see what they can do.
