stumpy Offline
#1 Posted : Monday, 31 July 2006 2:35:34 AM(UTC)
stumpy
Can anyone point me in the right direction with the right booster/master cylinder to suit my HK ute project. The car had a drum brake type master cylinder mounted to the firewall which i have tossed, thinking a HT/G disc style booster would mount straight up but not unless i start drilling holes in the firewall. I have a booster supposedly off a HT V8 Premier which does not fit. Anyone got any ideas?? ( Running HQ brakes )
#2 Posted : Monday, 31 July 2006 5:49:12 AM(UTC)
Hi Stumpy.
Any HK/HT/HG vacuum booster will fit your ute, as long as you have the correct brackets & pushrod etc.
All disc braked cars in these models, use the larger double diaphragm booster & there are 2 distinct types.
Early HKs, up to mid/lat
#3 Posted : Tuesday, 1 August 2006 6:40:33 AM(UTC)
Thanks Dr Terry, right again. There was a small dimple in the firewall and the pedal has the two holes in it. Your knowledge amazes me again. Cheers
