#1 Posted : Wednesday, 2 August 2006 7:16:03 AM(UTC)
what i need to know is will a vr-vs-v8-abs-irs diff centre go into a vq v8 statesman with irs but no abs with no trouble?
Edited by user Wednesday, 2 August 2006 11:26:21 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 2 August 2006 7:19:31 AM(UTC)
Sounds like an SMS?????
If you are trying to say can a VR/VS V8 diff fit in a VQ, or is the handbrake different, then the answer is complicated.
All VQ, VP, VR & VS IRS diff centres will interchange.
The only difference is the ABS sensors fitted
#3 Posted : Wednesday, 2 August 2006 7:55:22 AM(UTC)
cheers mick what i have is a vr-vs v8 abs diff centre irs,what i need to do is fit it to a v8 vq statesman without abs do you know if i will be able to bolt it up with no problems?cheers badboy
dsmith
#4 Posted : Wednesday, 2 August 2006 8:22:35 AM(UTC)
also mick the handbrake is different what do i do about that?cheers badboy
dsmith
#5 Posted : Wednesday, 2 August 2006 8:48:44 AM(UTC)
So the new diff has ABS, and the VQ doesn't?
If that's the case, just bolt it up, no probs at all.
Only swap the centre over - 4 bolts hold it to the K-frame. The hubs, arms, springs & driveshafts stay in the car & you reuse your old ones - so ther
#6 Posted : Wednesday, 2 August 2006 9:14:43 AM(UTC)
cheers mick
#7 Posted : Saturday, 13 January 2007 4:11:00 AM(UTC)
can you put a non abs centre into an abs car? (both from vq with irs)
#8 Posted : Saturday, 13 January 2007 6:27:25 AM(UTC)
By "centre" are you talking the gears only, or the entire "centre" assembly as a sealed unit?
If it's gears only, then it's a straight swap.
If it's the whole centre assembly, then you must keep the external ABS sensors & tone wheels for ABS.
Sen
#9 Posted : Saturday, 13 January 2007 6:33:30 AM(UTC)
yeah, i'm talking about changing the entire centre. Will the abs stuff bolt up to the non abs centre? Are those 'gear looking things' part of the drive shafts or part of the centre itself?
#10 Posted : Saturday, 13 January 2007 6:36:03 AM(UTC)
Also - to swap the centres should I remove the whole frame from the car or just change the centre in the car?
Thanks, Mark.
#11 Posted : Saturday, 13 January 2007 9:58:54 AM(UTC)
You won't be able to easily access the 4 bolts on the top to release it.
I have found you need to lower the K-frame a bit (loosen the front nuts, athough the bushes have a fair bit of play) and remove the rear diff mount to do this.
The "gear lookin
#12 Posted : Saturday, 13 January 2007 7:56:38 PM(UTC)
Thanks mate, if I get stuck I'll get back on here.
