basketcasebear Offline
#1 Posted : Thursday, 3 August 2006 10:52:09 AM(UTC)
basketcasebear
Is a red 308 the same as a vr>vs 308, except for heads and aspiration??
ptpro
DOH!!!
#2 Posted : Thursday, 3 August 2006 5:58:00 PM(UTC)
Almost. The VN/VG/VP/VR/VS-mid VSIII 304 doesn't have the block threaded for the 4 x short head bolts in the valley - the ones that are only half torqued on a red/blue/VK/VL 308/304. The cam is also different, but interchanges between blocks. Plus the las
#3 Posted : Thursday, 3 August 2006 7:59:23 PM(UTC)
basketcasebear
thanks for that byron, so it is possible to put later heads on earlier 308? and cam, with carby a straight gas??
ptpro
DOH!!!
#4 Posted : Thursday, 3 August 2006 11:11:44 PM(UTC)
Yes. And the heads are getting cheaper now as the engines wear out, and VN V8's are worth stuff all. I bought a pair the other day for $200. Brand new head bolts are also peanuts. Make sure when you buy the heads you buy the rocker covers too.
#5 Posted : Friday, 4 August 2006 5:24:00 AM(UTC)
basketcasebear
hey thanks 4 that byron, i wouldnt try it myself, dont know enough about how to do it, but seems that would end up with late model engine, power economy, etc. cheers
ptpro
DOH!!!
Guest (5)
This page was generated in 0.022 seconds.
