basketcasebear Offline
#1 Posted : Thursday, 3 August 2006 10:52:09 AM(UTC)
basketcasebear
Is a red 308 the same as a vr>vs 308, except for heads and aspiration??
ptpro
DOH!!!
#2 Posted : Thursday, 3 August 2006 5:58:00 PM(UTC)
Was thanked: 608 time(s) in 575 post(s)
Almost. The VN/VG/VP/VR/VS-mid VSIII 304 doesn't have the block threaded for the 4 x short head bolts in the valley - the ones that are only half torqued on a red/blue/VK/VL 308/304. The cam is also different, but interchanges between blocks. Plus the las
#3 Posted : Thursday, 3 August 2006 7:59:23 PM(UTC)
basketcasebear
thanks for that byron, so it is possible to put later heads on earlier 308? and cam, with carby a straight gas??
ptpro
DOH!!!
#4 Posted : Thursday, 3 August 2006 11:11:44 PM(UTC)
Yes. And the heads are getting cheaper now as the engines wear out, and VN V8's are worth stuff all. I bought a pair the other day for $200. Brand new head bolts are also peanuts. Make sure when you buy the heads you buy the rocker covers too.
#5 Posted : Friday, 4 August 2006 5:24:00 AM(UTC)
basketcasebear
hey thanks 4 that byron, i wouldnt try it myself, dont know enough about how to do it, but seems that would end up with late model engine, power economy, etc. cheers
ptpro
DOH!!!
