#1 Posted : Wednesday, 4 April 2007 2:54:30 AM(UTC)
I have looked hard and long at monaro numbers, and something just don't add up. Everywhere i have looked its telling me that there were 6147 hg monaros made.
Why is the stamp on the firewall of mine read( HG 07093 A )???
#2 Posted : Wednesday, 4 April 2007 5:02:57 AM(UTC)
Because there were over 100,000 HG's made and very roughly 1/4 of these were constructed in the Adelaide plant. Yours is ostensibly the 7093rd HG built in Adelaide.
If we all had the same (good)
#3 Posted : Wednesday, 4 April 2007 6:38:12 AM(UTC)
O ok so they were no Racial Discrimination between the 4 and 3 door ok thanks.
Do by chance you know what the first hg monaro number was or what numeral sequence they ran????
#4 Posted : Wednesday, 4 April 2007 7:08:56 AM(UTC)
They were just numbered in the order that they came down the line, so there is no sequence as such.
Warren
#5 Posted : Wednesday, 4 April 2007 7:29:29 AM(UTC)
Originally posted by charlie
O ok so there was no Racial Discrimination between the 4 and 2 door, ok thanks.
Do by ch
#6 Posted : Wednesday, 4 April 2007 5:08:30 PM(UTC)
The lowest chassis numbers from each plant in the HG are usually in the first 20 chassis numbers.
Adelaide and Sydney also numbered theie cars, so check your body plate to see which Monaro/GTS or GTS350 that you have.
Warren
#7 Posted : Wednesday, 4 April 2007 11:50:35 PM(UTC)
gidday warren
the body number read 001A na i wish.
it reads (body 168-A)
little plate reads 80737gl162565.
From what i gather its a gts adelaide built.
unsure if its a 6 or 8 cyl have you any clue from the numbers??
The fire wall reads hg 07093A
#8 Posted : Thursday, 5 April 2007 3:04:34 AM(UTC)
Yes its the 168th GTS 6 cylinder from Adelaide.
Warren
#9 Posted : Thursday, 5 April 2007 3:38:30 AM(UTC)
Thanks warren
Could you please let me know how you know its a 6 cyl.
And being a gts it would have to be 186s ???
#10 Posted : Thursday, 5 April 2007 6:32:49 AM(UTC)
186S is correct
#11 Posted : Thursday, 5 April 2007 7:19:19 AM(UTC)
737 is GTS 6cyl in HT and HG. 837 is V8 GTS. 1837 is GTS350.
