#1 Posted : Tuesday, 8 August 2006 8:11:43 AM(UTC)
Just thought id check what spline LJ toranas have? is it a coarse spline? also anyone have any suggestions what diff and what ratio to run behind a worked 202? thanks
#2 Posted : Tuesday, 8 August 2006 8:27:36 AM(UTC)
also what do you think about buying secondhand springs? about 12months old dobinson springs. do they deteriorate with age? i cant think of anyhitng that could be wrong with them just wondering if anyone had another opinion.
#3 Posted : Tuesday, 8 August 2006 8:27:36 AM(UTC)
also what do you think about buying secondhand springs? about 12months old dobinson springs. do they deteriorate with age? i can't think of anyhitng that could be wrong with them just wondering if anyone had another opinion.
#4 Posted : Tuesday, 8 August 2006 8:44:14 AM(UTC)
LJ's run a course spline Banjo diff, usually a 3.08:1 ratio. If you have a standard 4 speed, stay with the 3.08 unless you do minimal freeway/highway driving, then go for a 3.36:1. If you have a 5 speed with an overdrive 5th gear, run a 3.36:1 or 3.55:1.
#5 Posted : Tuesday, 8 August 2006 8:44:14 AM(UTC)
LJs run a course spline Banjo diff, usually a 3.08:1 ratio. If you have a standard 4 speed, stay with the 3.08 unless you do minimal freeway/highway driving, then go for a 3.36:1. If you have a 5 speed with an overdrive 5th gear, run a 3.36:1 or 3.55:1.
#6 Posted : Tuesday, 8 August 2006 6:20:29 PM(UTC)
Some LJs have fine spline axles, but AFAIK the fitment was limited to the Bathurst specials, possibly only the 1973 versions and onwards. I think you can readily get them made by converting Gemini axles by either changing the stud patterns or putting an L
#7 Posted : Tuesday, 8 August 2006 6:20:29 PM(UTC)
Some LJ's have fine spline axles, but AFAIK the fitment was limited to the Bathurst specials, possibly only the 1973 versions and onwards. I think you can readily get them made by converting Gemini axles by either changing the stud patterns or putting an
#8 Posted : Wednesday, 1 August 2007 8:37:56 AM(UTC)
i have a lh torri with 186 and aussie 4 speed what ratio banjo diff should i chuck in there 3.55 or 3.36?
#9 Posted : Wednesday, 1 August 2007 4:09:43 PM(UTC)
Depends upon the tyre size, what aussie 4spd it is and what sort of driving you normally do.
