The Yeti Offline
#1 Posted : Wednesday, 9 August 2006 1:02:18 AM(UTC)
The Yeti
Hi I'm planing my next project.
It will be a FX/FJ and as per the norm I want to fit a disc brake front end to it as a start, My question is almost every car I see at shows etc has also had a Rack & Pinion conversion as well, I have notised that rare's and CRS sell HR X members with and without the R&P is there a reason most people go for R&P as well or purly personal choise?
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
#2 Posted : Thursday, 10 August 2006 12:30:18 AM(UTC)
Hey mate, I've been told that the R&P steering is more direct, but you loose a bit of lock. i reckon you'd only do it if you wanted late model power steering or you old steering box is past it...I considered it recently but opted for a reco kit for the or
The Yeti Offline
#3 Posted : Thursday, 10 August 2006 7:09:55 PM(UTC)
The Yeti
Thanks slow poke I realy appreceate informed feed back
#4 Posted : Thursday, 10 August 2006 7:12:42 PM(UTC)
no problems, Hey is that your Yellow wagon? looks nice....
BrianH Offline
#5 Posted : Thursday, 10 August 2006 9:04:12 PM(UTC)
BrianH
Yeti
When people talk about steering being more direct they are usually referring to the turns lock to lock and how quickly the wheels turn. There is no particular type of steering system that does that better than others, it all comes down the ratios
#6 Posted : Friday, 11 August 2006 5:10:47 AM(UTC)
Front mounted Torana rack (shortened) on a HR front end, If done CORRECTLY, will give you better steering geometry than a CRS kit, Or pretty much any rear mounted rack.
I know Because i have one in my FX.
If you just fit a rack, with no fu
#7 Posted : Friday, 11 August 2006 11:52:44 AM(UTC)
Which Torana rack, Les? I assume LH/LX?
Cheers...Dave
BrianH Offline
#8 Posted : Friday, 11 August 2006 9:14:04 PM(UTC)
BrianH
Les
What are the correct stubs and steering arms as well? How much did you narrow the rack?
Brian
#9 Posted : Sunday, 13 August 2006 7:56:45 AM(UTC)
LH LX rack works fine, HR [b]DRUM[b/] brake stubs, HQ steering arms with stops cut off, reversed to stick forward, and tapers for tie rod ends reversed as well so that tie rod end comes in from the top, commodore tie rod ends, and unfortunately i cant tel
Guest (7)
