#1 Posted : Saturday, 7 April 2007 3:41:34 AM(UTC)
Hi
Want to remove a grey engine from my fx. The grey is attached to a red gear box using I believe an adapter plate?
What is the easiest way to remove the engine.
Take the engine out with the gear box - ie take both out together as one peice? or undo the gear box bell housing from the engine (leave the gearbox in place) and just remove the Engine only?
I 've read it easiest to take out the gear box and engine as one together.
I am a novice and are about to attempt an engine removal
what is the easiest way for someone learning
thanks
#2 Posted : Saturday, 7 April 2007 4:16:08 AM(UTC)
I have no experience with an FX but when ever I've done this sort of job I've taken the box and engine out in one piece, easiest to do by removing the radiator/grill/etc
HarryO Offline
#3 Posted : Saturday, 7 April 2007 4:37:02 AM(UTC)
HarryO
Taking the box with the engine is the easiest for sure. Can take some shakes of the car to detatch the shaft from the box. Make sure there is some padding for the shaft when she drops. Cheers.
gmholdman Offline
#4 Posted : Saturday, 7 April 2007 6:29:25 PM(UTC)
gmholdman
Where are you Jeff? I can help with proper lifting hook.
#5 Posted : Sunday, 8 April 2007 6:00:49 AM(UTC)
Hi gmholdman
I am in Northern Victoria
what do you mean by a propoer lifting hook?
I was just going to use chains
can you send a photo
thanks
Jeff
gmholdman Offline
#6 Posted : Sunday, 8 April 2007 7:13:13 PM(UTC)
gmholdman
Jeff, I'm in Melb, whats your e-mail?? Do you have a repair manual? if so check "special tools" AL.
Edited by user Sunday, 8 April 2007 8:26:13 PM(UTC)  | Reason: Not specified
#7 Posted : Monday, 9 April 2007 5:48:15 AM(UTC)
AL
email is [email protected]
I am interested in the lifting hook
assume what you have is original designed for gry motor?
how much do you want for it
thanks
