7 Pages<12345>»
Mr Void Offline
#41 Posted : Friday, 29 September 2006 8:02:24 PM(UTC)
Mr Void
Originally posted by johnperth
The plug kmocks out but you have to reach it by taking the sump off and using a long rod
___________________
#42 Posted : Monday, 2 October 2006 6:44:39 AM(UTC)
Been following this thread & its got me interested in a similar conversion. What kind of fuel pump are you using? Does inyone know if a Holley Blue will be sufficient to feed the EFI? Also, I assume the blue/black motors have the same pattern of bolts for
#43 Posted : Monday, 2 October 2006 6:44:39 AM(UTC)
Been following this thread & it's got me interested in a similar conversion. What kind of fuel pump are you using? Does inyone know if a Holley Blue will be sufficient to feed the EFI? Also, I assume the blue/black motors have the same pattern of bolts fo
#44 Posted : Monday, 2 October 2006 9:43:39 AM(UTC)
here is a interesting read on blue motors http://www.carpoint.com....alias=carpointau&id=7229
Titmar Offline
#45 Posted : Wednesday, 4 October 2006 6:19:38 AM(UTC)
Titmar
Hello sorry I have been away on holiday lucky me.
the answer to the beige hornet I am using the one I got with the motor out of the VK with a surge tank.I used a sump of a WB motor witch fit on no hassles.
Titmar
kraul Offline
#46 Posted : Monday, 16 October 2006 9:15:07 PM(UTC)
kraul
in reply to the Beige Hornet the VK carby motor came with a factory 5speed. the EFI only ever came with the auto as far as i know. the holley blue pump is not an efi pump so i doubt that it would work. im using a holley red to get the fuel upto the surge
kraul Offline
#47 Posted : Monday, 16 October 2006 9:23:12 PM(UTC)
kraul
Qn for titmar. how have you rigged up your surge tank and pumps? thats if your at that point yet. cheers
Titmar Offline
#48 Posted : Saturday, 21 October 2006 6:11:59 AM(UTC)
Titmar
Kraul yes I am at that point but i am thinking of putting a tank out of a VS ute witch already have a surge tank in it. I just have to see how much mucking around its going to take.
#49 Posted : Saturday, 21 October 2006 9:38:38 AM(UTC)
To make the VS tank fit, you would have to mount it where the spare wheel goes.As long has it doesnt sit to low. Holley red fuel pumps pump 7psi.Holley blue pump 14psi. Multi point EFI pumps nomaly run around 36 psi regulated and around 43 psi unregulated
#50 Posted : Saturday, 21 October 2006 9:42:45 AM(UTC)
The VK five speed came out behind the 173 (2.85) and are not a very strong box
Mr Void Offline
#51 Posted : Saturday, 21 October 2006 8:51:33 PM(UTC)
Mr Void
Kraul - I can post a pic of my setup in the HJ 1 tonner if you want... its just a layout since the whole lot needs a paint and wiring needs to be hidden etc.. but if you are after ideas as to where to mount stuff etc I can post a link.
________________
___________________
Mr Void Offline
#52 Posted : Saturday, 21 October 2006 8:51:33 PM(UTC)
Mr Void
Kraul - I can post a pic of my setup in the HJ 1 tonner if you want... it's just a layout since the whole lot needs a paint and wiring needs to be hidden etc.. but if you are after ideas as to where to mount stuff etc I can post a link.
_______________
___________________
#53 Posted : Sunday, 22 October 2006 12:31:38 AM(UTC)
Ta guys. Do you think the fact that the efi only came with the auto a comment on the efi, or the fragility of the 5 spd? Theres no reason it wont work well with a manual...?
The Beige Hornet.
Mr Void Offline
#54 Posted : Sunday, 22 October 2006 1:27:42 AM(UTC)
Mr Void
The vk efi ecu does not have anything at all to do with the auto or shift points etc so I don't see how there could be any problem with them working together.
But if they are a weak box it may not be the best choice for the box's life considering the efi
___________________
Mr Void Offline
#55 Posted : Sunday, 22 October 2006 1:27:42 AM(UTC)
Mr Void
The vk efi ecu does not have anything at all to do with the auto or shift points etc so I dont see how there could be any problem with them working together.
But if they are a weak box it may not be the best choice for the boxs life considering the efi 2
___________________
#56 Posted : Sunday, 22 October 2006 2:49:01 AM(UTC)
Hi Guys.
A bit of confusion here, I think Mr Void meant 173s (not 179s).
The BW 5-speed box was available only behind the 173 (2.85) in the VH series. In the VK the 173 (2850) was not available (in Australia anyway), but the BW 5-speed was available
Mr Void Offline
#57 Posted : Sunday, 22 October 2006 4:44:35 AM(UTC)
Mr Void
yeah...if I had have just looked 3 posts up I would have seen the 173! Too many numbers in my head at the moment.
Either way, presuming the 5speed bolts in with no issues is it a much weaker box then the M21 (hopefully got the right number that time!!
___________________
#58 Posted : Sunday, 22 October 2006 7:26:25 AM(UTC)
I dont think they are a huge lot weaker than a M21 but they are weaker and I would never call the all aussie 4spd box strong any way.But as with all gearboxs when the bearings are worn it has less tooth contact and is more likely to go bang if you give it
#59 Posted : Sunday, 22 October 2006 7:14:23 PM(UTC)
Hi Guys.
The 3 different manual gearboxes available behind the 202 EST (carby) motor in the VK are the M20 (not M21, that's the close ratio 304/308 box), the MC6 (Filipino) & the M76 BW 5-speed. Given that most VK6 cyls are automatic anyway, all 3 manu
#60 Posted : Sunday, 22 October 2006 7:14:23 PM(UTC)
Hi Guys.
The 3 different manual gearboxes available behind the 202 EST (carby) motor in the VK are the M20 (not M21, thats the close ratio 304/308 box), the MC6 (Filipino) & the M76 BW 5-speed. Given that most VK6 cyls are automatic anyway, all 3 manua
Guest (14)
7 Pages<12345>»
This page was generated in 0.091 seconds.
