7 Pages«<23456>»
#61 Posted : Wednesday, 25 October 2006 6:03:11 PM(UTC)
at the the top of the fuel tank there is a 1/4" return line inside that there is a plug with a half mil hole remove that to stop high pressure build up in the injecters. instead of having the preasure gauge of the clock you should run at about 2.5 - 3 bar
Mr Void Offline
#62 Posted : Wednesday, 25 October 2006 8:33:45 PM(UTC)
Mr Void
___________________
#63 Posted : Thursday, 26 October 2006 8:15:42 AM(UTC)
I ran the return line to the top of the overflow line at the tank and fitted a T piece to use both.
Titmar Offline
#64 Posted : Friday, 27 October 2006 5:19:36 AM(UTC)
Titmar
hello just wont to know if i sould use the WB wire lume or a HZ ,
witch would be easer
#65 Posted : Friday, 27 October 2006 7:51:22 AM(UTC)
If you are going EFI you can only use the VK EFI loom from the engine compartment.
Mr Void Offline
#66 Posted : Friday, 27 October 2006 10:24:09 PM(UTC)
Mr Void
Does the HZ have the resister wire to the coil? If so I'd go with the Wb so you can use the existing eng bay wiring to the coil and starter motor running to the factory bay connector (unless you are going to pull pins and redo the whole lot).
________
___________________
Mr Void Offline
#67 Posted : Friday, 27 October 2006 10:24:09 PM(UTC)
Mr Void
Does the HZ have the resister wire to the coil? If so Id go with the Wb so you can use the existing eng bay wiring to the coil and starter motor running to the factory bay connector (unless you are going to pull pins and redo the whole lot).
_________
___________________
#68 Posted : Saturday, 28 October 2006 7:39:00 AM(UTC)
To use the electronic ignition you have to cut out the resistor wire.
Titmar Offline
#69 Posted : Sunday, 29 October 2006 1:51:14 AM(UTC)
Titmar
hello yous the bloke that had the ute befor me had already pulled the dash out,so i have to find out where things go so i am just wondering has any one got a diaogram for a WB wire lome for the dash and bay.
thank Titmar
Mr Void Offline
#70 Posted : Sunday, 29 October 2006 2:51:09 AM(UTC)
Mr Void
___________________
kraul Offline
#71 Posted : Monday, 30 October 2006 2:48:45 AM(UTC)
kraul
finaly im nearly there. Iv managed to get it all up and running. just a few minor issues to sort out with a leaking holley pump. thanx to all the guys who gave me ideas
Mr Void Offline
#72 Posted : Monday, 30 October 2006 5:15:41 AM(UTC)
Mr Void
Congrats Kraul - great to hear it is a success!! Good work.
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
#73 Posted : Monday, 30 October 2006 11:57:45 AM(UTC)
Ummmm... the WB will also have the resistor wire, and in any case you don't need to muck about with the under wiring at all except to do the ignition bit.You have to do it all in the sharp end.
But to make it easy for the computer and get it out of all
#74 Posted : Monday, 30 October 2006 11:57:45 AM(UTC)
Ummmm... the WB will also have the resistor wire, and in any case you dont need to muck about with the under wiring at all except to do the ignition bit.You have to do it all in the sharp end.
But to make it easy for the computer and get it out of all t
#75 Posted : Monday, 30 October 2006 12:41:29 PM(UTC)
Why will the WB have a resistor wire John? They have HEI dizzies like VC/VH/VK EFI Commodores...
Cheers...Dave
#76 Posted : Monday, 30 October 2006 6:03:56 PM(UTC)
Hi Guys.
WB did not have a ballast resistor in the harness, as Dave said they use the same type of HEI dissy as the VC/VH etc.
Mr Void Offline
#77 Posted : Tuesday, 31 October 2006 1:51:15 AM(UTC)
Mr Void
I have the exact opposite problem to you John - I mounted the vk ecu behind and a little below the glovebox and due to the curve of the footwell I am having heaps of trouble unhooking the plug! If it could just be taked straight off rather than swinging l
Edited by user Tuesday, 31 October 2006 2:01:04 AM(UTC)  | Reason: Not specified
___________________
#78 Posted : Tuesday, 31 October 2006 10:31:10 AM(UTC)
Sorry wasn't aware of the WB electronic ignition.
I mounted the fuel pump relay just to right of the glove box back up under the dash, it's apparently important to mount it upright,.
I had to unpick the under engine wiring injector harness from just nea
#79 Posted : Tuesday, 31 October 2006 10:31:10 AM(UTC)
Sorry wasnt aware of the WB electronic ignition.
I mounted the fuel pump relay just to right of the glove box back up under the dash, its apparently important to mount it upright,.
I had to unpick the under engine wiring injector harness from just near
Mr Void Offline
#80 Posted : Tuesday, 31 October 2006 7:35:04 PM(UTC)
Mr Void
Thatnks for the John, I wasnt aware that the relay needed to be upright? Ive got mine on a 45 so itll have to be moved..
void
___________________
___________________
Guest (18)
7 Pages«<23456>»
