7 Pages«<4567>
Titmar Offline
#101 Posted : Thursday, 8 February 2007 9:03:47 PM(UTC)
Titmar
thanks wade this will help me alot.
thanks
Titmar
Titmar Offline
#102 Posted : Monday, 19 February 2007 7:58:07 AM(UTC)
Titmar
Hello yous I am still having the problem of tring to connect the plug from the wb nere the brake booster into the vk one, the wb one has 6 and the vk one has to many to count.could some one tell me a easier way , i have tried to follow the book but just g
#103 Posted : Monday, 19 February 2007 9:59:46 AM(UTC)
Suggest you get a Gregorys shop manual I found it more straightforward than the Holden VK one the holden one splits the pages and wiring so its hard to get continuity of viewing the Gregorys puts it all on one page, still a bit confusing because you have
Mr Void Offline
#104 Posted : Monday, 19 February 2007 9:22:30 PM(UTC)
Mr Void
Hmmm, not too sure what you are you trying to do there titmar? The plug from the vk loom goes into the efi control module, the only other wires go to the vk fusebox from memory - I was fortunate that I converted from manual to auto so had the hole in the
___________________
Mr Void Offline
#105 Posted : Monday, 19 February 2007 9:23:15 PM(UTC)
Mr Void
oh and the stuff is being scanned today, should be able to email to you in the next couple..
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
Titmar Offline
#106 Posted : Monday, 19 February 2007 10:48:04 PM(UTC)
Titmar
Sorry guys its the one that veers off from the light loom and has got your wiper and heater wires , by memory there are pink,red,blue,green,brown wires on the WB and alot on the VK one.
thanks Titmar
#107 Posted : Tuesday, 20 February 2007 1:32:17 AM(UTC)
what has that got to do with the efi?
Titmar Offline
#108 Posted : Tuesday, 20 February 2007 2:59:01 AM(UTC)
Titmar
that is what i am asking the one from the wb connector is from the fuse boxunder the dash and the vk one looks like it comes off the coil and distributor
#109 Posted : Tuesday, 20 February 2007 9:52:00 AM(UTC)
the pink should be ignition to coil. the blue/brown/ green I am pretty sure go to electronic ignition and coil, they can be separated from the VK loom and use the wb ones.
Titmar Offline
#110 Posted : Tuesday, 20 February 2007 10:39:29 PM(UTC)
Titmar
thank john that should pull me out of the sh** , just to many wires
thanks Titmar
Titmar Offline
#111 Posted : Monday, 26 February 2007 5:14:25 AM(UTC)
Titmar
thanks to john and wade i have finally got the ute to turn over i was getting confused with some wires , thay had changed a few colours on me.just waititng on my fuel tank to come and off she goes.
so thanks again guys Titmar
Mr Void Offline
#112 Posted : Wednesday, 28 February 2007 3:38:12 AM(UTC)
Mr Void
A GLORIOUS moment!! WOOHOO!!!!
From cranking to running took me more than a day - I worked out I had to change the resistor wire to the coil pretty quickly but then ended up with a faulty module on the dizzy...after checking and rechecking and recheck
___________________
Titmar Offline
#113 Posted : Thursday, 23 August 2007 11:10:10 AM(UTC)
Titmar
Hello boy sorry I havent been on line I have been away But I am back.
About my ute it is 90% done I have Been Driving it for a while but now I have Taken it off the road to finish the cab part of it, Having Trouble with the Fuel temp and oil guages. Do I
Mr Void Offline
#114 Posted : Monday, 27 August 2007 6:11:53 PM(UTC)
Mr Void
Oil and temp should be fine (though I am just presuming) but I have no idea about fuel - there are so many probas that can occur from the sender (or sender type) through the wiring and to the gauge???
___________________
___________________
#115 Posted : Tuesday, 28 August 2007 9:16:15 AM(UTC)
the oil sender will work perfectly with the gauge, at least it does with the HQ, I assume you are using the efi sender the wb one most likely wont work.
the fuel gauge should also work, but it has 3 connectors so you are going to have do some mods, shop
#116 Posted : Tuesday, 28 August 2007 9:16:15 AM(UTC)
the oil sender will work perfectly with the gauge, at least it does with the HQ, I assume you are using the efi sender the wb one most likely won't work.
#117 Posted : Tuesday, 28 August 2007 9:17:16 AM(UTC)
#118 Posted : Tuesday, 28 August 2007 9:17:16 AM(UTC)
Titmar Offline
#119 Posted : Saturday, 1 September 2007 5:19:27 AM(UTC)
Titmar
Thanks guys I will have a go the week end and I will let you know how I go, and yes I am using the EFI ones
#120 Posted : Tuesday, 9 October 2007 10:07:02 AM(UTC)
has any one out there got a wiring diagram for the gauges out of a gts dash.
thanks titmar
Guest (36)
7 Pages«<4567>
