#1 Posted : Monday, 9 April 2007 5:12:34 AM(UTC)
Hi, can someone give an answer on whether all the HD range had ball joint front, or was it introduced sometime during the model. Thanks
#2 Posted : Monday, 9 April 2007 5:19:20 AM(UTC)
p.s. I thought that the last of the HD series could have been ordered with ball joint/disc brake fronts.
stopgo Offline
#3 Posted : Monday, 9 April 2007 5:46:04 AM(UTC)
stopgo
Never seen a facory HD with balljoints
Only HR
However as you say...... some late ones might have got the new gear
#4 Posted : Monday, 9 April 2007 5:53:10 AM(UTC)
Thanks mate. They definately had them, just require confirmation on when they were introduced.
#5 Posted : Monday, 9 April 2007 5:54:42 AM(UTC)
I believe it was late in the run that they got the upgrade, but yes definately some HDs had the options.
#6 Posted : Monday, 9 April 2007 5:58:41 AM(UTC)
Thanks Reaper. Just surfing the net trying to confirm this question and saw your shed posting on.....
http://gallery.oldholden.com/sheds.php
#7 Posted : Monday, 9 April 2007 6:03:27 AM(UTC)
Plenty of images to go through there Vern, over 3000 ;)
I think at one time I might have read Dr Terry say the upgrades were introduced closer to the middle of the HD run than the end (whereas I always thought it was late) and Dr Terry would be the man
vintageholden Offline
#8 Posted : Monday, 9 April 2007 6:10:01 AM(UTC)
vintageholden
#9 Posted : Monday, 9 April 2007 6:13:02 AM(UTC)
Yep, Dr Terry and Warren. They are wealths of knowledge. (just giving credit where credit is due)
No doubt this, like many subjects has already been raised on this site, though can be very difficult to find old posts.
#10 Posted : Monday, 9 April 2007 6:16:33 AM(UTC)
Originally posted by vintageholden
hd premier had ball joints
#11 Posted : Monday, 9 April 2007 9:53:41 PM(UTC)
Hi Guys.
There were actually more HDs made with ball joints than king-pins. All HDs produced from Jan to May '65 had king-pins, then all HDs from 1st June '65 to early '67 had ball joint front ends. When the ball joints were released, the disc brake op
#12 Posted : Monday, 9 April 2007 10:54:15 PM(UTC)
Hi Guys.
A correction to that last post.
It should read "then all HDs from 1st June '65 to early '66 (not '67)had ball-joint front ends".
Dr Terry.
#13 Posted : Monday, 9 April 2007 11:32:47 PM(UTC)
Thanks Dr Terry for clearing that up, I'll have to try and remember what you've said this time.
peter_flane Offline
#14 Posted : Wednesday, 11 April 2007 12:18:50 AM(UTC)
peter_flane
So Terry would it be a correct assumption that all HD utes and vans had ball joint front end, as they were released later?
#15 Posted : Wednesday, 11 April 2007 3:18:49 AM(UTC)
Hi Peter.
AFAIK that is correct, also I've never seen an HD ute or van with king-pins.
Dr Terry.
#16 Posted : Sunday, 15 April 2007 5:36:39 PM(UTC)
can i use LJ torana stub axles to start a disc conv on a HR. its running drums right now
peter_flane Offline
#17 Posted : Sunday, 15 April 2007 6:18:55 PM(UTC)
peter_flane
They will bolt on. Simply I would say no, don't do it. The kingpin inclination angle will be too far out to get a decent wheel alignment. In the hundreds of disc front conversions on old Holdens I have seen, only a couple have had Torana stub axles, and t
#18 Posted : Tuesday, 17 April 2007 8:22:31 AM(UTC)
Thanks guys, particularly Dr Terry for the production dates. This has confirmed my assumption.
#19 Posted : Tuesday, 17 April 2007 10:01:40 AM(UTC)
Kev I agree with peter_smol. I have checked HQ HT LJ and LH and only HR is Right for HR. Even with longer bolts and the upper control arms pressed on to the frame it was just not right.Spend the bucks and get the HR stubs its a lot easier in the long run.
This page was generated in 0.124 seconds.
