hi all i got a 351 clevo ive removed the bolt that holds the dizzy in the the block and i can not move the dizzy by hand does any know wat might cause it to be stuck????????????????? thanks slick
probably wont be stuck just a little tight. give it a good yank.
Spray some inox or wd40 around the dizzy shaft. Let it sit overnight and then try moving it. A dizzy can "grow" inside the block if left over time. Had an XC electronic dizzy stuck fast once, we had to kill it to get it out of the block.
will try that thanks guys
