#1 Posted : Monday, 9 April 2007 7:18:59 PM(UTC)
hi all i got a 351 clevo ive removed the bolt that holds the dizzy in the the block and i can not move the dizzy by hand does any know wat might cause it to be stuck????????????????? thanks slick
camlj Offline
#2 Posted : Monday, 9 April 2007 10:15:19 PM(UTC)
camlj
probably wont be stuck just a little tight. give it a good yank.
Paul351xb Offline
#3 Posted : Tuesday, 10 April 2007 1:39:15 AM(UTC)
Paul351xb
Spray some inox or wd40 around the dizzy shaft. Let it sit overnight and then try moving it. A dizzy can "grow" inside the block if left over time. Had an XC electronic dizzy stuck fast once, we had to kill it to get it out of the block.
#4 Posted : Tuesday, 10 April 2007 2:53:32 AM(UTC)
will try that thanks guys
