#1 Posted : Thursday, 17 August 2006 2:37:33 AM(UTC)
Can someone please explain the part that the crank angle sensor (built into the VS 5.0L distributor) plays in the ignition system. I understand that it reads the position of the crankshaft and from that, tells the CPU when to send a signal to the spark plugs and injectors.
Does that cover it or is there more to it?
#2 Posted : Thursday, 17 August 2006 6:36:03 PM(UTC)
Hi Richard.
It's a bit like a set of points. It tells the spark when to fire & being an EFI system it tells the injectors when to open.
Dr Terry.
#3 Posted : Saturday, 19 August 2006 4:42:51 AM(UTC)
Thanks Dr Terry.
