Can someone please explain the part that the crank angle sensor (built into the VS 5.0L distributor) plays in the ignition system. I understand that it reads the position of the crankshaft and from that, tells the CPU when to send a signal to the spark plugs and injectors.
Does that cover it or is there more to it?
Hi Richard.
It's a bit like a set of points. It tells the spark when to fire & being an EFI system it tells the injectors when to open.
Dr Terry. |
