#1 Posted : Thursday, 17 August 2006 3:55:10 AM(UTC)
Hi all,
I have a leaking sump plug....(if it's not one thing it's the next hey!) upon closer inspection the sump plug does not fully tighten up like it is cross threaded or something....what should i do???? can i simply replace the plug or am i up for a new sum?
thanx..
pete
#2 Posted : Thursday, 17 August 2006 4:28:59 AM(UTC)
You have 2 options:
1. An oversize sump plug, and tap the thread to suit.
2. An OEM sump plug, but tap the thread bigger, and insert a helicoil to bring it back on size.
___________________________________________________________
GMH1975 Offline
#3 Posted : Thursday, 17 August 2006 5:31:05 PM(UTC)
GMH1975
Are you posative it is cross threaded?
it might just need a washer(gasket).
Holden sell white nylon type washers for the injected 5 liters so that might help if you if it aint crross threaded.
Not the BLOODY Kingswood
CherryBomb Offline
#4 Posted : Friday, 18 August 2006 8:54:15 AM(UTC)
CherryBomb
1) Re-Tap the tread out. And fit a new bolt plug.
2) weld the Plug in, Find a replacement plug/bung and weld that in.
I'd be cautious to Heli coils as they dont seem to be water tight... In my experience.
Dan
Never stop being inspired,
You
#5 Posted : Sunday, 20 August 2006 7:36:38 AM(UTC)
Just buy a tap and run it in there to clean out your damaged threads. Is it 1/2" UNF (SAE) . . . I think. Someone else might know the correct thread.
#6 Posted : Friday, 25 August 2006 4:17:07 AM(UTC)
Our VS 5.0L Berlina sump plug used to leak. Fixed it 100% with a healthy dose of plumbers thread tape wrapped around it.
This page was generated in 0.115 seconds.
