Hi all,
I have a leaking sump plug....(if it's not one thing it's the next hey!) upon closer inspection the sump plug does not fully tighten up like it is cross threaded or something....what should i do???? can i simply replace the plug or am i up for a new sum? thanx.. pete
You have 2 options:
1. An oversize sump plug, and tap the thread to suit.
2. An OEM sump plug, but tap the thread bigger, and insert a helicoil to bring it back on size.
Mick ___________________________________________________________ |
Are you posative it is cross threaded? it might just need a washer(gasket). Holden sell white nylon type washers for the injected 5 liters so that might help if you if it aint crross threaded.
Not the BLOODY Kingswood |
1) Re-Tap the tread out. And fit a new bolt plug.
2) weld the Plug in, Find a replacement plug/bung and weld that in.
I'd be cautious to Heli coils as they dont seem to be water tight... In my experience.
Dan
Never stop being inspired, You |
Never stop being inspired, You may never realize your full potential. |
Joined: 29/07/2006(UTC) Posts: 766 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
Just buy a tap and run it in there to clean out your damaged threads. Is it 1/2" UNF (SAE) . . . I think. Someone else might know the correct thread.
Our VS 5.0L Berlina sump plug used to leak. Fixed it 100% with a healthy dose of plumbers thread tape wrapped around it.
