#1 Posted : Thursday, 17 August 2006 7:24:11 AM(UTC)
How much would it cost to get the body of a panelvan bead blasted? Am looking at restoring mine and was throwing up some ideas? cheers
#2 Posted : Sunday, 20 August 2006 7:44:22 AM(UTC)
With glass beads? Im not sure if the glass beads would remove paint as well as garnet or other stuff. Chemical striping is the way to go I think. They just paint it on and blast it off with water and thats it. I had my car acid diped and zinc pacifate pla
#3 Posted : Sunday, 20 August 2006 10:50:58 AM(UTC)
Yes and you get acid into all the joints and nooks and crannies and melt out all the sealants which you can never get sealed properly again. then it rusts out from between the joints. Glass beads will remove paint easily I used them with my hobby blaster.
peter_flane Offline
#4 Posted : Monday, 21 August 2006 6:38:11 AM(UTC)
peter_flane
If we have a car we are restoring at work that the owner has had the panels acid dipped, we have to take all of the door skins off and clean all traces of acid, then refit the skins. It creates more rust than ever in the joints and ruins good panels. We s
peter_flane Offline
#5 Posted : Monday, 21 August 2006 6:39:06 AM(UTC)
peter_flane
cocko where are you located?
Vintage Caravans Offline
#6 Posted : Monday, 21 August 2006 7:33:03 AM(UTC)
Vintage Caravans
Hi was wondering if anyone can reccomend a blaster in Melbourne Northeren Suburbs, (I am up near Thomastown if that helps, I have doors and panels to get done
Matt
MSN Messenger = [email protected]
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#7 Posted : Thursday, 24 August 2006 11:05:30 AM(UTC)
hey there peter im located in geelong vic.
peter_flane Offline
#8 Posted : Friday, 25 August 2006 4:35:58 AM(UTC)
peter_flane
In all honesty you are limited to Geelong. There would only be so many blasters in Geelong. Ring them all and the list will get cut right down as a number of them won't do large items, or cars, or whatever reason. Then work from there.
peter_flane Offline
#9 Posted : Friday, 25 August 2006 4:35:58 AM(UTC)
peter_flane
In all honesty you are limited to Geelong. There would only be so many blasters in Geelong. Ring them all and the list will get cut right down as a number of them wont do large items, or cars, or whatever reason. Then work from there.
#10 Posted : Wednesday, 2 April 2008 1:21:12 AM(UTC)
Does anyone know a bead blaster in the Eastern Suburbs (Knox/Ringwood)?
#11 Posted : Wednesday, 2 April 2008 6:12:15 AM(UTC)
Try Melbourne Soda Blasting. I think there may be some advantages over normal bead blasting.
Guest (11)
