VL05 Offline
#1 Posted : Saturday, 19 August 2006 7:30:57 AM(UTC)
VL05
G'day guys, posted up a while ago about the Uni project I'm doing on project management, I've decided to look at the VN Commodore, so over the next few weeks I'll be asking a few questions.
First up, what month and year was the series 2 released? And what were the problems from series 1 that were corrected?
Also, what month in 1991 did the VN's cease production.
If anyone has any general info on the VN I'd be very happy to hear it, not in terms of construction but anythin to do with budget/problems/reasons for doing certain things in the project, basically any of the aspects to do with the management of the project, I'd appreciate it alot!
WANTED: HJ/Q/X/Z van in W.A. pm me!
WANTED: GTS rims, seats and mirrors to suit HJ.
#2 Posted : Saturday, 19 August 2006 9:16:45 AM(UTC)
Hi VL05.
This VN series 2 question arises often, but it depends on what you define as being a series 2.
To explain, the VN was officially released on 17 Aug '88, in V6 form only. The V8 version including the SS etc, was released on 14 Mar '89. The '
#3 Posted : Saturday, 19 August 2006 9:22:08 AM(UTC)
Technically there is no series 2, the first commodore model to use that term was the VP (although the VQII was the first "V-car")
There was the first round of upgrades, the XX8 as Terry noted, actually appeared over a few months from November 89 thru t
Edited by user Saturday, 19 August 2006 9:25:45 AM(UTC)  | Reason: Not specified
VL05 Offline
#4 Posted : Saturday, 19 August 2006 9:31:40 AM(UTC)
VL05
Ok thanks guys so far.
But from reading of Commodore magazines and other forums (I guess by people not as in the know as you guys) it is commonly said that the series 1 had a whole lot of "problems" and these problems were rectified with the Series 2.
#5 Posted : Saturday, 19 August 2006 5:42:16 PM(UTC)
I suggest you get hold of 2 service manuals.
VN volume 10 (blue cover), and VN/VG/VQ volume 3 - 1991 upgrade (orange cover).
They will explain all the changes in great detail.
_____________________________________________________
#6 Posted : Sunday, 20 August 2006 1:32:04 AM(UTC)
some problems which occurred in early VN`s were faulty alternators, water leaks , also early VN`s do not have a brake light in the back window.
#7 Posted : Sunday, 20 August 2006 1:55:07 AM(UTC)
Add timing chain (weak), O2 sensor's!! Hood liner falling down, yeah it happens with old age but even ricer's older than the VN still have no dramas.
Can anyone else confirm front strut problems? mine let go at around 65000k's
I don't know if balancer s
#8 Posted : Monday, 21 August 2006 6:22:25 AM(UTC)
some time in 89 , I worked at GMH from 87-mar 90. The last 9 months i was there I was on water test inspection and 85% of VN`s had water leaks in various areas
#9 Posted : Monday, 21 August 2006 6:36:55 AM(UTC)
End of June '89 was when the 3rd brake light came in.
I have seen a 28/6/89 without it, but every july '89 one I have seen has had one.
The ADR requirement for it came into play on 1/7/1989
#10 Posted : Monday, 21 August 2006 11:20:07 PM(UTC)
Hi Guys.
Mick, I use the common industry term 'eye-level brake light' because on VN sedans, it's actually a 5th brake light, not a q3rd, because they already have 4 !!. On the VP they changed this & only had 3 total, including the eye-level brake light
This page was generated in 0.066 seconds.
