#1 Posted : Monday, 21 August 2006 10:04:43 PM(UTC)
Has anyone done a V6 conversion on an early Holden and managed to mount both steering pump and AC pump up high on the ecotech engine. I have seen the VN series I with the AC pump mounted where the P/S pump goes, but this is not possible on the ecotech.
Alternatively will the A/C compressor remain in its place when fitting V6 to FE/C. From what I can see it will not.
Any help appreciated.
Warren
#2 Posted : Tuesday, 22 August 2006 2:06:28 AM(UTC)
Hi Warren,
To date the only way I have seen it done is to use the new front end from V6 conversions. This new front end allows the use of the standard commy engine mounts and hence the A/C is left at the standard location.
I looked into a few options w
Edited by user Tuesday, 22 August 2006 8:08:03 PM(UTC)  | Reason: Not specified
gmholdman Offline
#3 Posted : Tuesday, 22 August 2006 4:41:55 AM(UTC)
gmholdman
Warren, have a ecotech in a FJ and had to remount the compressor next to the alternator useing an a/c mount from Pat Gardiner but I removed the power steering pump and used a pulley Al.
#4 Posted : Wednesday, 23 August 2006 10:32:24 PM(UTC)
Thanks for this, as long as it can be done, will contact Pat Gardiner, any one have his contact details.
Warren
#5 Posted : Thursday, 24 August 2006 3:47:00 AM(UTC)
http://www.v6conversions.com.au/
#6 Posted : Thursday, 24 August 2006 8:47:36 AM(UTC)
Hi Warren,
I know this isn't exactly what you asked for, but it may be helpful...
http://members.ozemail.com.au/~brettsueferguson/air_con.htm
HTH
Cheers...Dave
