Jvanner Offline
#1 Posted : Tuesday, 22 August 2006 1:04:53 AM(UTC)
Jvanner
hi, does anybody know what the difference from the Gen 3 timing chain set up from and that of an older style cast iron 350. i was told the block is the same casting but its just made of aluminium. And 2nd. if the same,can you put straight cut timing geard into a gen 3 and problems if any with these gears.... Jamie
#2 Posted : Tuesday, 22 August 2006 4:09:47 AM(UTC)
The Gen3 block shares nothing with the cast iron ones except the bore spacing dimensions.
This page was generated in 0.017 seconds.
