#1 Posted : Thursday, 31 August 2006 4:58:32 AM(UTC)
whats wrong with my fuel sender unit in my hz wagon? i got a replacement from rare spares. when i gave it to my mechanis it did not match the sender unit already in my tank. rare spares were excellent, as they had sent wrong unit out. so i get my new unit that is the corret 1 for my hz wagon. but again it does not match what is already in my car. mine has 2 pipes exiting from the fuel sender unit. my mechanic told me it looks to be a return pipe or a breather. but the new replacement from rare spares does not have 2 pipes exiting. i am lost and unsure. has the previous owner used a sender unit from a different holden, or can i just replace it with the part from rare spares and ignore the other pipe and hose???? any help greatly appreciated - sorry about the long winded explaination
cheers geoff
#2 Posted : Thursday, 31 August 2006 5:46:05 AM(UTC)
Hi geoff.
The HX/HZ V8s with factory A/Cond have a vapour return line to the tank, this is what the extra pipe is for. Can't you get your's reconditioned at Rares. It might take a little longer, but I think that's the only way you're going to get the c
#3 Posted : Thursday, 31 August 2006 6:57:50 AM(UTC)
thank you Dr Terry. will let my mechanic know. so we can work it out. unfortunately, my hz is my daily driver so makes getting it recoed difficult. but thankyou again for the answer muchly apreciated.
cheers geoff
