joelm Offline
#1 Posted : Sunday, 15 April 2007 4:07:23 AM(UTC)
joelm
hi all,
recently got a nice little smiths tacho- (written on face is: RVI 5000/00A) off ebay and need some help on the how to hook it up. i get the basic premise of wire to ignition to power it and then connect to the coil but am at a loss which wires go to which.
Heres the info:
coming from the back there are the following wire:
- white (no trace)
- white (no trace) which has been cut off v close to tacho body
- green (no trace)
- red (white trace) i assume this is power from the ignition?
- red (no trace) does this go to positive on coil?
- black (no trace) does this go to negative on coil?
Also on the back at the top there are 2 wire positions- brown for 8 cylinder & blue for 4 & 6 cylinder.
Any suggestions on how to wire it up to my EJ Special wagon?
Should it have a fuse in the circuit anywhere?
Thanks in advance,
Joel
138 Grey fresh rebuild, mild cam, ported head, twin single strommies, extractors.... and a hole in my wallet to match.
#2 Posted : Sunday, 15 April 2007 8:23:27 AM(UTC)
Hi Joel,
While I don't know the specific wiring for your tacho, most aftermarket ones follow this:
White - Dash Lights
Green - Coil Negative
Red - Ignition Feed
Black - Earth.
Is it a shift-light or adjustable redline/rev limiting tacho? Maybe
#3 Posted : Sunday, 15 April 2007 5:37:51 PM(UTC)
Hi Joel.
This sounds like what they call an 'impulse tachometer'. They were marketed by Smiths in the '60s and are wired differently to modern tachos. I remember fitting one for a guy once. You will have to ask an 'older' more experienced instrument gu
joelm Offline
#4 Posted : Monday, 16 April 2007 3:08:57 AM(UTC)
joelm
cheers dave, but there is no shift light or rev limiter. Its definately old school as Dr.Terry suggests.
i might give it a go with the white in series, as my web search thus far hasnt come up with anything. but any more suggestions will be greatly appr
#5 Posted : Monday, 16 April 2007 8:21:58 PM(UTC)
Joel,
I have one of these on my shelf I don't remember the exact wiring as I pulled it from a car 20yrs ago. I have recently decided to use it again as it is a very nice old tacho.
The clue on old Smiths Gauges is the RVI or RVC. RVI is an inline cur
madjack Offline
#6 Posted : Monday, 16 April 2007 11:57:33 PM(UTC)
madjack
Joel
I've got a vague recollection that the two white wires for the series coil connection are polarity conscious. I recall that after converting an MGB from positive to negative earth the tacho wouldn't work until those wires were reversed.
I don't hav
joelm Offline
#7 Posted : Thursday, 26 April 2007 10:22:50 AM(UTC)
joelm
Thanks to all for the assistance.
In case anyone else has the same problem, the setup is:
black and green to Earth
Red to ignition
red with white trace to dash lights
one of the white wires connects to original coil wire (which previously went di
#8 Posted : Thursday, 26 April 2007 10:59:14 AM(UTC)
Hi Joel,
Thanks for letting us know.
Cheers...Dave
