Fastlane
Holden Forums
Holden General Discussion
how do i hook up a Smiths Tacho? RVI 5000/00A
hi all,
recently got a nice little smiths tacho- (written on face is: RVI 5000/00A) off ebay and need some help on the how to hook it up. i get the basic premise of wire to ignition to power it and then connect to the coil but am at a loss which wires go to which.
Heres the info: coming from the back there are the following wire: - white (no trace) - white (no trace) which has been cut off v close to tacho body - green (no trace) - red (white trace) i assume this is power from the ignition? - red (no trace) does this go to positive on coil? - black (no trace) does this go to negative on coil?
Also on the back at the top there are 2 wire positions- brown for 8 cylinder & blue for 4 & 6 cylinder.
Any suggestions on how to wire it up to my EJ Special wagon?
Should it have a fuse in the circuit anywhere?
Thanks in advance,
Joel 138 Grey fresh rebuild, mild cam, ported head, twin single strommies, extractors.... and a hole in my wallet to match.
Hi Joel,
While I don't know the specific wiring for your tacho, most aftermarket ones follow this:
White - Dash Lights Green - Coil Negative Red - Ignition Feed Black - Earth.
Is it a shift-light or adjustable redline/rev limiting tacho? Maybe
Hi Joel.
This sounds like what they call an 'impulse tachometer'. They were marketed by Smiths in the '60s and are wired differently to modern tachos. I remember fitting one for a guy once. You will have to ask an 'older' more experienced instrument gu |
cheers dave, but there is no shift light or rev limiter. Its definately old school as Dr.Terry suggests.
i might give it a go with the white in series, as my web search thus far hasnt come up with anything. but any more suggestions will be greatly appr
Joel, I have one of these on my shelf I don't remember the exact wiring as I pulled it from a car 20yrs ago. I have recently decided to use it again as it is a very nice old tacho.
The clue on old Smiths Gauges is the RVI or RVC. RVI is an inline cur
Joel I've got a vague recollection that the two white wires for the series coil connection are polarity conscious. I recall that after converting an MGB from positive to negative earth the tacho wouldn't work until those wires were reversed. I don't hav
Thanks to all for the assistance.
In case anyone else has the same problem, the setup is:
black and green to Earth Red to ignition red with white trace to dash lights one of the white wires connects to original coil wire (which previously went di
Hi Joel,
Thanks for letting us know.
Cheers...Dave
Fastlane
Holden Forums
