dagwoodone Offline
#1 Posted : Sunday, 3 September 2006 8:26:14 PM(UTC)
dagwoodone
How hard is it to do a rear main on a vs v6 .I am thinking the pulling of the box out is relatively easy no different to a turbo 400 or trimatic .
I have been told by the RWC bloke there is a plate on the rear of the block similar to a timing cover that holds the rear main and that the plate also could be a cause of the leak as well.Is it adviable to replace the plate and the seal as a pcakge? has any one done one as ive got 5 days to do this job or inhave to pay for another rwc . Any help advise would be appreciatted .Dazza
red Offline
#2 Posted : Monday, 4 September 2006 3:25:49 AM(UTC)
red
they arent too hard, just remove gearbox and replace the plate and seal. just remember when you remove plate coolant will come out so maybe drain coolant and do oil change after.
dagwoodone Offline
#3 Posted : Monday, 4 September 2006 3:52:25 AM(UTC)
dagwoodone
Thanks for that i will start tuesday night after i get the plate and seal .Are they cheap from Holden or expensive ? Thanks for the reply RED and HoldenOn
