#1 Posted : Wednesday, 6 September 2006 4:43:28 AM(UTC)
G'day
I am currently after a 5 speed gearbox to put behind my 202, I was told that this gearbox would fit up without much change. How true is this? any help would be very appreciated.
#2 Posted : Wednesday, 6 September 2006 8:46:34 AM(UTC)
It goes this way:
A 202 is just a bigger 173 (externally the same). A Starfire is a 173 with the middle two pistons removed, hence the back of it looks just like a 202. So the box will bolt straight up. Just beware of clutch diameter and gearstick loca
#3 Posted : Wednesday, 6 September 2006 9:31:21 AM(UTC)
I was told the boxes were as strong as a 6 cyl one but had different 1-4th gear ratios, bit lower.
#4 Posted : Wednesday, 6 September 2006 7:29:29 PM(UTC)
Thanks for the info guys, i'll have a go with the starfire box and see what happens.
#5 Posted : Wednesday, 6 September 2006 10:04:29 PM(UTC)
