4 Pages<1234>
#21 Posted : Thursday, 19 October 2006 6:42:17 AM(UTC)
Hi guys was wonderin, i have same problem as all u guys and was wondering if it really was the abs module, did it fix the problem...
#22 Posted : Thursday, 19 October 2006 6:42:17 AM(UTC)
#23 Posted : Saturday, 3 February 2007 5:49:21 AM(UTC)
I am having the same problem as well. I have taken out the ABS fuse and the warning light for ABS and TRACTION CONTROL stays on and the others go out. but today the other warning lights came on as well. Will changing the ABS module fix the other warning l
#24 Posted : Saturday, 3 February 2007 5:49:21 AM(UTC)
I am having the same problem as well. I have taken out the ABS fuse and the warning light for ABS and TRACTION CONTROL stays on and the others go out. but today the other warning lights came on as well. Will changing the ABS module fix the other warning lights from coming on. They come on when the fuse is removed. Please email me with a price on a replacement ABS module please to [email protected]
#25 Posted : Sunday, 4 February 2007 10:58:03 AM(UTC)
Can any one tell me if a faulty BCM will bring up a code saying that the SDM has a internal fault Or has any one heard of problems with the SDM. This is on a 1999 v6 VT sdn.
#26 Posted : Sunday, 4 February 2007 10:58:03 AM(UTC)
VT ACCLAIM Offline
#27 Posted : Wednesday, 28 February 2007 11:39:20 PM(UTC)
VT ACCLAIM
I have a 02/98 VT Acclaim with traction control experiencing exactly same problems as Engee
my VT is experiencing the same problems that the other subscribers reported. ABS, Trac Off, Engine Warning Lamp and Air Bag light comes on after about 15 mins
VT ACCLAIM Offline
#28 Posted : Wednesday, 28 February 2007 11:39:20 PM(UTC)
VT ACCLAIM
my VT is experiencing the same problems that the other subscribers reported. ABS, Trac Off, Engine Warning Lamp and Air Bag light comes on after about 15 mins driving. Both fans kick in, temperature gauge freezes, AC doesnt work. These symptoms sometimes disappear after another 15-20 mins. The low oil pressure lamp also comes on at the same time but not in every case. Sounds like the ABS module problem you suggest. Any help or contact email would be appreciated.
#29 Posted : Thursday, 1 March 2007 2:59:37 AM(UTC)
For help with this, E-mail Dr Terry through his profile or call Bebco Automotive in Sydney.
Cheers...Dave
#30 Posted : Thursday, 1 March 2007 2:59:37 AM(UTC)
Cheers...Dave
#31 Posted : Thursday, 17 May 2007 8:25:38 PM(UTC)
had same problem on a VX Clubsport R8......got a Reco ABS Module fitted at Borgy's Motor Spares in Sunshine VIC 03 9312 3333...cost $280 and they fitted it while I waited...they kept my old one to send to QLD for reconditioning. Holden quoted $700 for a
#32 Posted : Thursday, 17 May 2007 8:25:38 PM(UTC)
had same problem on a VX Clubsport R8......got a Reco ABS Module fitted at Borgys Motor Spares in Sunshine VIC 03 9312 3333...cost $280 and they fitted it while I waited...they kept my old one to send to QLD for reconditioning. Holden quoted $700 for a new ABS module fitted.
#33 Posted : Friday, 20 July 2007 10:59:54 AM(UTC)
Originally posted by claire
Thank heavens! I thought I was the only one with a dodgy VT Calais. All the warning lights and bells go off nearly every trip, except (usually) first thing in the morning. Its driving me crazy, was about to get the car an exorcism!
clary8
#34 Posted : Friday, 20 July 2007 10:59:54 AM(UTC)
#35 Posted : Thursday, 6 September 2007 8:08:03 AM(UTC)
Hi,
I have been experiencing similar problems with my 99 VT Acclaim Auto. But not quite the same. The car has been recently serviced but the dealership could found no evidence of the problem, ie no codes retained in BCM or ABS module, with the answer tha
#36 Posted : Thursday, 6 September 2007 8:08:03 AM(UTC)
Hi,
I have been experiencing similar problems with my 99 VT Acclaim Auto. But not quite the same. The car has been recently serviced but the dealership could found no evidence of the problem, ie no codes retained in BCM or ABS module, with the answer that it might (!!!) be the ABS module ($700 plus please). We recently replaced the keys using the Mr Minit cheaper option. This all worked fine with the key registering OK with the BCM etc. The dealership knew all this and didnt suspect this as problem. We have had the car stall at idle or coming to idle, with traction control indicator flashing on, but being able to restart thankfully. The car always unlocks and starts fine first thing in the morning. But after a drive we have also experienced intermittent inability to unlock and restart (a real problem if you have stopped to get fuel!!). But after 5 or minutes, everything works again. Is this the ABS module or something else??? Help please, it is driving us crazy!!!!
#37 Posted : Monday, 5 November 2007 6:23:04 AM(UTC)
Hi Guys,
I have a VT 97 Exec, recently it has started to shutter and almost stall when idoling and driving slowly. Also, not sure if this is a related problem but when I accelarate it is slow to react and jumps around, and still shutters around.
I have been told it could be a problem with the fuel injectors or an electrical problem??
Any suggestions would be greatly appreciated.
#38 Posted : Monday, 5 November 2007 6:23:04 AM(UTC)
Hi Guys,
I have a VT '97 Exec, recently it has started to shutter and almost stall when idoling and driving slowly. Also, not sure if this is a related problem but when I accelarate it is slow to react and jumps around, and still shutters around.
#39 Posted : Monday, 5 November 2007 6:41:41 AM(UTC)
Hi Hunch.
It's most likely ignition leads. Check to spark plugs & measure the ignition coils while you're there.
#40 Posted : Monday, 5 November 2007 6:41:41 AM(UTC)
Hi Hunch.
Its most likely ignition leads. Check to spark plugs & measure the ignition coils while youre there.
Guest (12)
4 Pages<1234>
This page was generated in 0.176 seconds.
